| Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
95 5.0 mustang serious problems
So picked up a mustang a few months ago. When I got it, it was studdering and accelerating weird, so I took it in and had the mass airflow sensor replaced (Thats what they said was wrong.......). The car ran like a top, but then just yesterday after letting it sit for about a week (Only drive it about once or twice every two weeks) it started all over again, this time worse, stalling, studdering, and sometimes just not starting at all. Checked the coil, replaced the distributor cap, and found out the little metal peice on the end of the rotor had fallen off, replaced the rotor, tried again, car still doesnt run right....something I'm missing? Something that needs to be reset?
Something easy? Not injectors?
01 Grand Cherokee Laredo V8 94 Dodge Ram 2500 Cummins Turbo Diesel - SOLD |
Re: 95 5.0 mustang serious problems
Were you able to retrieve the little metal piece or is it in the distributer?
You need fuel, air, and spark.
Did you check fuel delivery? Spark? When cylinder #1 is at TDC, where is the rotor pointing? Is it pointing at the #1 spark plug wire on the cap? |
Checked spark, got that. I'll check to see if the rotor is pointing to 1 on TDC.
I have a dumb idea. A friend of mine had this problem with an 87 Mustang 4 cyl. The car would run for a bit, studder and then die or not start at all. Someone told him to replace the fuel cap. So he did and the car runs perfectly. Try it, it may help.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex -1999 Ford F150 |
Hi,
I've Got A 6cyl 95 Mustang. I Had A Semilar Prob. If Your Trouble Is When You Are Accelerating It Might Be The Pre Filter On The Fuel Pump. Are Even The Pump Or Main Filter Out Side The Tank. The Pre Filter Is In Side The Tank Attached To The Pump. And Believe It Or Not Its Easy To Get To. Just Empty The Tank, Drop The Straps( 2 Screw I Think) And There It Is. Then Undo The Retainer Ring On Top Of The Pump And Slide Pump Out. You Can Leave All The Hoses Hooked Up If You Want ( I Did). After You Get The Pump Out You'll See The Filter. I Just Cleaned The Filter On Mine, But Im Shure That The Part Is Probably Under 10 Bucks. Anyway Thats How I Fixed My Trouble. Hope This Story Helps. Good Luck, N2trukn Ps. The Ford Shop Had No I Idea What Was Up With Mine. Also, The Computer Was Showing Low Voltage Accross The Mass Air Sensor. They Replaced Fuel Pump And Outer Filter. It Seemed To Fix It, But 15 Min Later ( After I Left The Shop ) It Started Up Again. |
I have a 95' mustang 3.8 and, I have a 89' 5.0 that I would like to swap the motor from and install it into the 95'. Will the 89' motor drop right in with no problems and if so,will the 5-speed tranny in the 3.8 work with the 5.0 motor. I am quite sure that I will have to change the computers and harnesses. Any help or advice would be greatly appreciated. I'm going to get rid of the 89 body if this exchange would work with not too many difficulties. Anyone want an 89' body (Free)!
