| COMPLETELY off-topic Talk about anything other than cars. But you can't be mad and angry in this forum! |
Iron Oxide
i know rust is iron oxide, but i wan wonder if there was a quicker/better way to get it? scraping the rust off something just doesn't give up very much
Re: Iron Oxide
Magnesium. When Magnesium is burned it produces its own oxygen. Thats why flares work underwater.
-Mike AF Director of Media / Photographer ![]() [email protected] | AutomotiveForums.com | Flickr Gallery |
Re: Iron Oxide
so if i burn magnesium i will get iron oxide?
Re: Iron Oxide
If you want iron oxide just find some rust. All iron oxide is is just oxidized iron because of a low carbon content in the steel. Lots of things oxidize, the statue of liberty for instance, its made of copper, but its green because it oxidized.
Re: Iron Oxide
there are companies that produce chemicals, you can get it from them if you have some kind of license. other than that, you'll just need to scrape away.
also, magensium can't possibly produce its own oxygen, it's a metal, oxygen can't just appear. and when it burns it uses oxygen.
Mr. T doesn't pity anyone who likes the Black Eyed Peas. He just kills them. Mr. T speaks only when necessary. His main form of communication is folding his arms and slowly shaking his head. And regardless of the situation, he is always understood. On the A-team, Face , Haniabal, and Murdoch were all masters of disguise. Mr T didn't have to wear a disguise. The bad guys didn't recognize him out of fear. |
Re: Iron Oxide
With the proper makeup hydrogen explosions can be avoided. The same thing can happen in a humid climate. Magnesium can also break down the air around us to form nitrides releasing oxygen, and magnesium oxide.
Re: Iron Oxide
ok thanks, that makes much more sense. one questions though, how do you ignite it? do you just need to get it up to a certain temperature (to achieve the activation energy for this reaction) or will i happen at room temperature and temperature increase will just speed it up?
Re: Iron Oxide
The only way I've ever lit it is over a bunsen burner in an open flame.
Re: Iron Oxide
i meant how would you light it under water, i've lit it in chemistry class with a bunsen burner as well.
Re: Iron Oxide
Re: Iron Oxide
Steel wool rusts quickly, and falls apart.
Magnesium and water? I know sodium and water will spontaneously ignite. |
Re: Iron Oxide
it doesn't spontaneously ignite but apparently if you can get it to ignite it will pull the oxygen out of the water to fuel the combustion.
Re: Iron Oxide
Hey whats the difference between IronOxide and Iron(III)Oxide?
Re: Iron Oxide
Learn something new everyday
Re: Iron Oxide
iron(III) oxide means it's an ionic compound with iron(III) ions and oxygen ions. you can also get iron(II) oxide that is an iron(II) ion with an oxygen ion. it's difficult to explain in writting but i hope you get the idea. the 2 chemicals, iron (II) oxide and iron (III) oxide, have different chemical properties and physical properties. i think iron (II) oxide is black, and iron (III) oxide is orange-ish, normal rust colored.
