Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 07-16-2006, 10:06 PM
123212321 123212321 is offline
Struts?
I thought I read somewhere that lots of wheel hop could be a result of worn out struts?
If this is a high chance of the problem: how much does a new set cost and is it hard to do alone with a jack and a toolset?
THANKS GUYS!
Sorry, I only realized this was the wrong section after I posted. I have a 1990 300zx if it helps.
Old 07-17-2006, 02:11 AM
Broke_as_****'s Avatar
Broke_as_**** Broke_as_**** is offline
Re: Struts?
http://www.courtesyparts.com/z32/oe_shock-front_na.html
http://www.courtesyparts.com/z32/oe_shock-rear_na.html
http://twinturbo.net/net/viewmsg.asp...&msg_id=941241
1989 240SX Fastback. . . . . . . . . . . . . . . . . . . . . . . . . . . 1995 300ZX Twin Turbo
Warning: Objects in mirror aren't as fast as they thought they were.
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
Re: Struts?
THANKS GUYS!
nah...the 300zx is notorious for wheel hop. you need subframe spacers or subframe bushings. to install the bushings you have to drop the whole subframe but for the spacers it can be done.
worn struts may contribute to the problem but not your biggest culprit.
a full metric set of wrenches and sockets and maybe a breaker bar is the main things you will need for a strut change but you will also need a spring compressor. manual spring compressors can be purchased from a local parts store for pretty cheap.
good luck. suspension can be a pain to work on.
ZedEx Crew Member #4
Old 07-17-2006, 01:48 PM
ExTrEmEDrIfT's Avatar
ExTrEmEDrIfT ExTrEmEDrIfT is offline
Send a message via AIM to ExTrEmEDrIfT Send a message via MSN to ExTrEmEDrIfT Send a message via Yahoo to ExTrEmEDrIfT
Re: Struts?
and dont get a cheap manual strut compressor because they suck and the cheap ones tend to bend and break ....
Past Z Car Crew
[The Enemy Of Your Enemy is Your Friend]
>>Keep Your Friends close : But Keep Your Enemies Even Closer <<
Old 07-17-2006, 04:04 PM
Z Cars Fanatic
Re: Struts?
mine has been fine for 12 shock changes.
Old 07-18-2006, 10:13 PM
xXxRocker5150's Avatar
xXxRocker5150 xXxRocker5150 is offline
Send a message via AIM to xXxRocker5150
Re: Struts?
in my case I had to take a torch to the rear shock bolts becuase they were so damn rusted. good luck...
Georgey on the subject of midget beastiality pornos
Originally Posted by 1viadrft
I've seen a video or two out of curiousity.... those damn midgets are hung! But then the donkey walks in...
Home Puta's 4Life Crew Member #1
R.I.P Andy, you will be missed by all.
