Old 07-16-2006, 07:55 PM
95astroman 95astroman is offline
'95 Astro's dash lights intermittent
My '95 Astro's dash lights don't work unless the interior is warm. All gauges and accessories work fine. While driving at night with the headlights on the dash lights turn on after the heater has warmed up the interior. I can sometimes smack the dash with my fist to get the dash lights to go on.
Old 07-16-2006, 08:25 PM
Blue Bowtie's Avatar
Registered Offender
Re: '95 Astro's dash lights intermittent
Does this include the radio lighting? If so, the problem is more likely closer to the dimmer control or tap from the tail light fuse to the INST lamp fuse. Checked the fuse panel and fuse condition lately?
Old 07-16-2006, 09:49 PM
The radio and AC/heater control lights are fine, and the dimmer works fine. It's the the dash lighting that's the problem. Does it sound like a lose/bad connection or a bad ground to the circuit board behind the dash. The temperature issue stumps me. Warm they work and cold they don't.
Old 07-16-2006, 09:55 PM
More on this....when I say dash lights I mean the lighting for the speedo and engine instrumentation.
Old 07-17-2006, 01:17 AM
Registered Offender
I suspected you were asking about the instrument lighting, which is why I asked about the radio lighting. I would suspect the rectangular bulkhead connector and copper foils in the rear of the I/P.
Old 07-17-2006, 08:06 AM
Thanks again for help on both problems. From what I've read on other threads, I've also got an EGR with some carbon holding it open. The info from this website is far more useful than a tech manual.
Old 07-18-2006, 12:26 AM
Rupesy's Avatar
Rupesy Rupesy is offline
I had similar problem. they seems to work when they wanted to. I just took out the instrment panel, repositioned it and screwed it back on. I haven't had a problem since.
Jon
93 Chevy Astro EXT 218k
93 BMW 525 170k
Old 11-15-2006, 07:50 PM
softail095 softail095 is offline
They must have changed things in 97. my 97 astro dash lights will not come on unless the dash is cold (<50 deg F) and I live in Arizona. Part of same prob is high beam ind lite and turn signal lites are reversed, off when should be on and on when should be off. The odometer light is ok, radio clock is ok and they work with dimmer control. I tried the closed fist on the dash but no effect (maybe I need a bigger fist)......... help! why temperature effects it?
