Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 07-16-2006, 04:00 PM
mtcs's Avatar
mtcs mtcs is offline
Send a message via AIM to mtcs Send a message via MSN to mtcs
Post Big Brakes vs. high performance pads/discs
I have been thinking of getting a big brake kit by stoptech. The problem is that the kits are expensive as hell. Are they really so much better than just changing the pads and discs for some high performance ones?
1996 ECLIPSE GST
2.3 Storker, 6 bolt, XACT flywheel, ACT Clutch, B&M shifter, DC SPORT Carbon steel strut tower bars, EVO2 exhaust, 1000cc injectors,Aeromoive rail, MBC boost controller, PTE 6152SP, SBR exhaust manifold, TIAL BOV, SBR FMIC, TEIN SS, Walbro fuel pump, AEM EMS, AEM UEGO, FP turbo intake, Aeromotive FPR, Magnus intake, 62mm throttlebody, Stoptech big brake kit, brembo rear slotted discs, Stage 2 Shep transmission (quafe), sparco fighter seats, sparco harnesses
Old 07-16-2006, 04:50 PM
Killa's Avatar
Killa Killa is offline
Re: Big Brakes vs. high performance pads/discs
If I have money I go with Brembo, I saw those big brake it on most factory car, subaru wrx, and even on some BMW, I love the way it look, If you want stop power and for look for big brake kit ( Brembo is my favore ). Since I think my car already have big brake on it , save money for wheel or dsmlink.
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 07-16-2006, 05:00 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Are you planning on road racing or autoX? If not, its wasted money IMO. I would definately go with some 2g AWD "big brakes" if you can get them onto a FWD, but I think the huge brembo units are vast overkill for anything short of a serious road/autoX racer. Plus getting bigger rotors adds to the rotating mass and moves the rotational center (I think thats the right term I cant remember physics was a long time ago) outward causing an extra drivetrain loss. Same thing with getting big rims.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 07-17-2006, 02:06 AM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Like Thor said if you are looking to do Auto X or Road racing then yes StopTechs are awesome they have a great feel to them and they arent overkill.....I have driving dsms with both Stoptech and Brembos and the brembos were overkill like crazy....If you are just going to be drag racing then I would just get some slotted rotors and some ugraded pads. Hope that helps...
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 07-20-2006, 10:32 PM
gsxeclipse97 gsxeclipse97 is offline
Send a message via AIM to gsxeclipse97
well we did some research on brakes here at the dsm shop and you can use the vr4 calipers wich would be a large upgrade
MODS
, 2g pistons, cyclone intake manifold, ported 1g head, 60mm tb, greddy type s bov, apex-i n1 exhaust , ngk spark plugs, 3 angle valve job, autometer boost/vac, autometer air/fuel ,autometer oil pressure ,cross drilled rotors ,turbonetics boost controller ,air filter ,remove dump tube, 14b turbo
and the ac still doesn't work and its been almost 3 years
