Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '83 - '90
Old 07-16-2006, 10:57 AM
toppknott toppknott is offline
1990 Jetta 4000 rpms at 70 mph
I have owned this jetta for 5 years and when I purchased it the instrument cluster did not work so I never noticed the unusual high rpms while cruising at 70. Recently I replaced the instrument cluster and noticed that when I was crusing at 70 I was at 4k rpms. I am pretty sure the tach is correct because it idles at the correct rpm. I am planning to go on a long trip (4000 miles) and I am trying to get everything ready and this is the last major problem I still have to address. any suggestions would be apperciated.
Old 07-17-2006, 02:15 PM
Doug Tatham Doug Tatham is offline
Re: 1990 Jetta 4000 rpms at 70 mph
I know how you feel. Fortunately for me the wind noise is so great at that speed that I don't notice the engine whinning. The car was built when all the speed limits were still 55 and geared so that it would get the best fuel efficiency at that speed. I won't make a long road trip in mine. If necessary, keep an eye on your temperature and oil level. Change your oil before and after the trip.
You could also try taking highways instead of the interstate.
Old 10-15-2006, 08:19 PM
jammyjim jammyjim is offline
If it is a five speed, you can install a taller fifth gear . If its an auto, im beat.
Old 10-27-2008, 11:20 PM
bryant.barber bryant.barber is offline
if it is a five speed shift out of fourth. mine is stock and i hit 75 at 3k. and 70 at 4k in 4th. if it is automatic.... toss it and find u a five-speed.
Old 10-27-2008, 11:21 PM
you may want to check your tire size to if they are to small this may happen
Old 12-03-2008, 07:34 PM
denisond3 denisond3 is offline
I dont understand? Whats the problem with the engine turning 4000 rpm? Its not a long stroke big block engine after all. I have a 90 Jetta also, automatic, and dont plan to mess with the gearing.
