Old 07-16-2006, 09:25 AM
patoffspyder patoffspyder is offline
Micromesh kits?
Hi guys
I want to buy a kit a Micromesh, containing soft touch pad from 1500 too 12000.
Someone can tell me if those pads can be used over and over or generally, after a kit or two, I need to throw them to the garbage?
Thanks!
Old 07-16-2006, 10:03 AM
cyberkid's Avatar
cyberkid cyberkid is offline
Re: Micromesh kits?
From what I've seen most poeple can use the lower grits for around 5-6 kits. the higher grits (5000+) last a lot longer due to less usage.
Please read the following linked articals before posting a question.
Once you have and still have questions, try to post your questions clearly.
This will make a lot of people's blood pressure drop back to normal, including mine.
NEW TO THE AF MODELLING FORUM? PLEASE READ THIS FIRST
AF Car Modeling Tutorial, How-To and Product Review Depository
AF Car Modeling Frequently Asked Questions [FAQ] - * Look here first! * ver2.0
And finally,I wish you all happy modeling
Old 07-16-2006, 10:15 AM
Re: Micromesh kits?
Thanks for your help, gonna try one of those kits then.
Old 07-16-2006, 10:59 AM
freakray freakray is offline
AF Modelrater
Re: Micromesh kits?
If you wet sand with water which has a small amount of dish soap diluted in it, it will prevent the pads from clogging and increase their lifespan.
AF User Guidelines
Old 07-16-2006, 12:04 PM
ZoomZoomMX-5's Avatar
Re: Micromesh kits?
As Ray mentioned, wetsanding w/a small amount of detergent helps. Also clean the pads or cloths after use and let them dry. They last a long time w/proper care.
My Fotki Album
