Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 07-16-2006, 09:24 AM
Kobun169 Kobun169 is offline
Exclamation how do you know if center dif is out
hey guys i just wana know how you can tell if you center dif is out. like how can you tell. and also if your transfer case is bad can some one help me.
Old 07-16-2006, 03:46 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: how do you know if center dif is out
If the center diff's spider gears are broken, the car will bind up in tight turns. It's not uncommon to see a DSMer doing figure 8s in the back of the pits after a mean launch to make sure nothing broke If you cut the case in half (I only know 2 other cases besides me on this one) the car won't move unless you have a welded VC or VC eliminator. Similar situation if the tcase is broken.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-16-2006, 04:52 PM
well like when i turn it turns tight and it is like the car locks up and feels like the rear wheels slip like something is broke.
Old 07-16-2006, 05:28 PM
AF - Advisor
Sure sounds like a broken center diff
Kevin Jewer
Old 07-16-2006, 05:40 PM
Killa's Avatar
Killa Killa is offline
holy shit, is that problem cause by launch too hard, or no maintain ( check and change fluid ) ?
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 07-16-2006, 05:55 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
I think a bit of both Killer, but from Kevins above post, I would think its the launching that actually does it in.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 07-16-2006, 06:05 PM
Killa's Avatar
I never launch my car before, but I fell the car move fast on every stop light. I will try to launch the car, after the dealer fix the leak, that will be tomorrow.
GM FOR LIFE !!
95 camaro lt1
Old 07-16-2006, 08:27 PM
AF - Advisor
Wheelhop is the number one killer of center diffs, which naturally occurs most often on a launch. The trouble comes when the pieces of the spider gears get out and ruin the rest of the tranny
Kevin Jewer
Old 07-16-2006, 09:27 PM
so you guys think it is my tranny and transfer case? shoul i change both?
Old 07-17-2006, 09:19 AM
AF - Advisor
I'm pretty sure we decided it was the center diff. The tcase has nothing to do with this. I guess I have to start putting less info in my posts.
Pull the diff to see if it's broke, and to send it out for an upgrade. Speed Design has always been good to me. Shep can also do it if you have to send the tranny to get rebuilt. Which brings us to the next point. While the tranny is opened up to pull the diff, check the rest of the parts for damage. If you are not capable of doing this yourself, send the whole tranny out to shep or TRE for repair/upgrade.
Kevin Jewer
Old 07-17-2006, 02:39 PM
Thor06's Avatar
Jizzed In My Pants
I dont think thats a good idea.
Old 07-17-2006, 07:34 PM
well i guess when i buy my new/used motor i will get the tranny with it since it is like 400 dollars more.
