| Cavalier Problem Diagnosis Got a problem you can't fix? We can help. |
cooling fan/toggle switch
ok so i had overheating problems before. trouble shot and did everything, found out the ecm isnt telling the fan to come on, so i put in a toggle switch, recently my car suffered some front end damage, i shut my car off after this damage and the fan was still going so i ripped out the relay out of frustration (because i knew it would shut it off), then i ripped apart the front end and replaced the rad that was cracked, then the rest of the parts, filled it back up with coolant and started it the fan would not come on again tried everything to fix it checked fuses and relays they are all fine. Any solutions other than getting a new ecm.. thanks
Re: cooling fan/toggle switch
run it directly to a toggle...or..a new ecm...your fan motor might not be any good either..
so i found the solution, im an idiot lol, i forgot i disconnected the battery so i had to wait a few mins before the fan kicked back in thanx anyways
