Old 07-15-2006, 10:24 PM
sLADe781 sLADe781 is offline
AC/Idle Problem
Before I get flamed, yes, I did do a search on the topic and my situation is slightly different....bear with me as I want to be as detailed as possible...
Okay, so I was driving today and it was hot so I decided to turn on the AC since my parents always bash me for not using it. I turn it on for about 10 minutes and when I arrive at my destination, my car just dies. I turn off the AC, start my car and my idle just goes up to about 1.5K and drops and just dies again. It does that a couple times and I somehow manage to park my car so I go out and check a couple things: brake fluid is full (because my brake lights came on), MAS is snug, engine oil okay.
Well, I keep trying to start it and it won't hold and noticed that I always keep my clutch down even after my car started up...so what I did was start up my car and released my clutch really quick. My car shakes a bit as it tries to gain some type of idle and it eventually does--really low at about 500. I let it warm up a bit, the idle still around 500, and then start driving home. The whole time while I was driving my idle would just idle randomly: sometimes at 500, sometimes at about 200, and sometimes normal at around 700-800. I was trying different methods as I was driving home to see if I could get it to idle properly during stops--holding the clutch down, releasing the clutch, holding the brakes, releasing the brakes, and combinations of the two. I tried everything and there was no pattern/explaination to its random idles so I concluded that it was just that....random.
When I arrive home, I do a couple more test but this time, with the AC. I start my car and it idles randomly, I turn on the fan and as soon as I push the AC button, my car just shuts off. I tested that about 3 times and everytime it does the same thing. I stop for about 5 minutes and then try it again: start car and it idles about 600, turn on the fan, then when I turn on the AC the idle drops to about 100 but the car is still on. It's on for about 2 minutes but when I turn the AC off this time, my car dies. Just when I thought I was getting some type of pattern everything goes back to being random.
Okay, so I come in and do a search and some reading...
1-my AC belt was changed about 2 years ago so I don't think its that. It was also tight on the pulleys so I think it's okay.
2-my plugs and wires were replaced about a year ago: stock plugs with Accel wires.
3-a couple members mention the IAC and I have that out right now but haven't fully cleaned it up yet since I don't have any electrical cleaner at the moment.
So there you have it...help!?! Besides the IAC, what do you guys think it could be? Also, I wasn't planning on opening the interior of the IAC like Jeff Lucius to clean it and was just gonna clean the exterior...do you think it'll be better if I just did both?
I don't know when the battery and alternator was last replaced but seeing that I was able to drive home for about 20 minutes, I don't think they are the problem.
Finally, the last thing that was done to my car was when I got it smogged about a month ago. The guy took off this one piece and the car started to shake really bad but then he put it back and everything thing seemed okay. I couldn't see what he took off but I think it might have been some tube because he pulled off those little tube clamps that are usually on rubber hoses (he was on the passenger side when he did that)...don't know if it has anything to do with my situation but I just remember the shaking of my car.
Okay guys, any guidance you guys could give me would be greatly appreciated. Thanks for the help fellas...
Old 07-16-2006, 11:06 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: AC/Idle Problem
first off, definitely check the IAC. and i would disassemble the whole thing, clean it inside and out, then reassemble. electric parts cleaner? brake cleaner works fine. anything with a high vapor pressure so it evaporates and doesn't linger.
secondly, although everyone likes to quickly rule-out the battery and alternator, these two components are the most common adn thusly are the most problematic. easiest way is to take your battery to autozone (or a local parts chain) and they should test it for free. they should also do this with you alternator, but its not fun removing that b/c you have to remove the belt.
but when you press the A/C button, the idle drops adn the car dies, that leads me to believe that its battery related, not alternator related. but i could be wrong b/c those two are always a sticky area as to what causes the other to do what.
so battery, IAC, then let us know.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 07-16-2006, 12:31 PM
Re: AC/Idle Problem
UPDATE: This morning I went to Kragen and bought some electrical parts cleaner and cleaned the outside of the IAC. I tried opening up the interior as well but the 3 screws won't budge and I don't have the bench vice like Lucius so I just stopped seeing that the screws were beginning to strip. After I cleaned it, I let it dry for a bit and put everything back in. I go to start my car and my idle goes up and comes down and the car dies. Did that about 4 times and then I wait for about 30 seconds, start it up and it struggles and shakes as it tries to get some type of stable idle....finally does. Everything looks normal and I let my car run for about 15 minutes to let the ECU relearn everything. After 15 minutes, I decide to take it for a test drive and on my way down the driveway, my idle drops to about 200 again so I just stop and come back up. By this time it is idling at about 600.
I try my AC and when I turn it on, my idle drops to about 400 and when I turn it back off, it goes to about 600 again.
Any thoughts guys? Linebckr49, I'll bring my car over to AutoZone later today to see if they could test the battery and alternator for me. Thanks for advice. They should be able to do both inside the car, right?
UGH, this is so frustrating....if anyone has any other bright ideas then I'm all ears. If it's definitely the IAC, I'll just suck it up and buy a new one seeing that my car's a daily driver and I can't afford to have it out of commission for an extended period of time. I'll post back after I get my battery & alternator checked. In the meantime, any other ideas would be greatly appreciated. Thanks guys!!!
Old 07-16-2006, 07:14 PM
Re: AC/Idle Problem
Okay, I just got back from AutoZone and Kragen:
1-AutoZone tested both the battery and alternator and the guy said it was fine. I told him of what was going on and he said that he thinks my idle adjuster is out of alignment and that I just needed to realign it. He said that it happens a lot to Mitsubishi cars and that he worked on a lot of Eclipses and Talons and that's what happened.
It's possible I guess but just doesn't make sense. I mean, if my idle adjuster was out of alignment then it should always idle at a constant RPM, right? If it was low it'll always be low and if it was high it'll always be high. My idle jumps back and forth all the time randomly so I don't think that is the problem...what do you guys think?
2-I took my car to Kragen to get a second opinion and the guy tested my battery, alternator, and starter. He said all was fine but my voltage during startup was a bit low but it was fine. I told him of the symptoms and he said to replace the fuel filter and air filter to begin with. Air filter was just replaced about a year and a half ago so I don't think that's the problem. Fuel filter I remember has been mentioned by a couple people here so maybe?
3-I was talking to this guy who knows a bit about cars and told him my symptoms and he said that he had a similar thing happen to his Eclipse. He said that the shop he took it to replaced his air manifold gasket. I don't know if that has anything to do with it but yeah...just thought I'd throw it out there....
So here we are back to square 1. Both battery and alternator are fine. Exterior of IAC has been cleaned but still the same symptoms. What to do next? I need help guys...any guidance will be appreciated. I really don't want to have to take it to a shop but if I have to, I guess I'll have to. I'll wait for you guys' help first though....stressing...no good...
Old 07-16-2006, 07:59 PM
Igovert500's Avatar
blue + red light magnet
Re: AC/Idle Problem
Air and fuel filter...no don't think so. The AC wouldn't have any correlation to those. If the battery and alternator are fine, I'd really lean towards the IAC, I'd really recommend getting it open somehow and cleaning it, or replacing it. You should be able to find one on ebay for around $50. I'm 90% sure that will fix the problem.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 07-16-2006, 08:47 PM
Linebckr49's Avatar
Re: AC/Idle Problem
+1 on the IAC. all that trouble you reported in ur 2nd and 3rd posts seemed to do nothing whatsoever. you tested all that stuff from your 1st post. it wouldn't benefit you to do the same thing again, however, i know when you're frustrated its hard to think clearly and be productive, especially in the summer heat.
i can't imagine how hard it is to remove and disassemble the IAC. IAC motor as described by Jeff Lucius is very simple, though his description may be detailed and lengthy. obviously, if the screws wont budge, try some rust penetrant. still no luck, i'm sure you have a friend that has a vise (or you could use this as an opportunity to get a vise!). the total disassembly, clean, test, and reassembly shouldn't take more than 1 hr. there just aren't that many parts.
93 3000GT base
Old 07-17-2006, 12:51 AM
CALPC89 CALPC89 is offline
Re: AC/Idle Problem
slade781 these problems have happened to my 94 mitsu. twice already and both times it was the alternator
Old 07-17-2006, 11:54 AM
Re: AC/Idle Problem
Hmm...interesting...I already had my alternator checked so I don't think that's the problem...
Well, turns out that my sister's bf does have a vise so I'll be heading there after work to use it.
Stealthee also mentioned that the pintle is supposed to spin (not sure if it's the metal part or the plastic piece) but mine didn't budge when I tried to turn it. I was also doing some research and found this one site where this guy describes that the pintle is supposed to go up and down smoothly when you turn the car to on without starting it but mine only goes up and down the first time. It wasn't smooth though... After I use the vise I'm gonna head on over to Sears to pick up a multi-meter too so I'll run Lucius' test.
Either way, since a lot of you are pointing to the IAC, I'll be getting a different one. Vert's 90% is a pretty darn good coupled with Stealthee and Linebckr's opinion on the matter. I'll keep you guys updated...thanks again for all the help guys. I really appreciate it...
Old 07-22-2006, 05:56 PM
Re: AC/Idle Problem
Okay, so my part came in today and I installed it. Started her up and the idle was a bit low compared to usual at about 1000 (on initial start ups it usually idles about 1200). So I let her warm up for about 10 minutes and by this time, it is idling about 700. I turn on the AC and it goes up a bit to 800--then it seems as if the ECU kicks in and brings it up to 900. When I turn on the second option for AC the idle shoots up to about 950. But when I turn it off, it goes back down to about 500. It doesn't drop to 100 and then come back up to 500 but it is automatically idling at 500. Tried it 2 more times and the same symptons came up. I haven't tried taking it for a test drive yet but so far, that's what I have.
So what do you guys think? Do I just have to turn up the idle (BISS-black cap, right?)? Or do you think the problem is still lingering somewhere... Because I'm pessimistic, I'm thinking the problem is still out there. If it is, that was $150 down the drain.
Anyways, let me know what you guys think. This sucks man...I really need my car up and running soon....
Old 07-22-2006, 06:12 PM
jd-autotech jd-autotech is offline
Re: AC/Idle Problem
if you have a known good battery out of something else and swap it and then see what happens i have seen this before and after the zone said it was good
Old 07-22-2006, 06:48 PM
Re: AC/Idle Problem
I thought certain cars took only certain batteries? Can I use a different car's battery on my car?
Well, I took my car out for a test drive and have the same symptoms. My car didn't die but the idle fel really low and was about to die a couple times. Damn this sucks....what could it be? The ECU???
Oh, and I changed both the O-ring and the IAC.
Old 07-22-2006, 08:55 PM
Linebckr49's Avatar
Re: AC/Idle Problem
so you ended up buying a Used IAC instead of cleaning your's? i thought you were gonna use ur buddy's vise to disassemble adn clean the IAC, then test with the multi-meter?
after what has happened, may i suggest again: disassemble and clean the IAC, test it. it could be perfectly plausible that you purchased a USED (at least i think it was used, you didn't say one way or the other) IAC, and it needs to be cleaned.
93 3000GT base
Old 07-22-2006, 10:56 PM
Re: AC/Idle Problem
Linebckr49, I bought a brand new one so it's not the IAC. And yes, I did open my old IAC: opened it, cleaned it, put everything back together again. Ran the test and got: 1-2: 30.6 2-3: 30.6 4-5: 32.1 5-6: 30.9 (turns out that my dad did have a multi-meter....he just didn't know what it was called). Still, same thing. I guess I should have posted that one night when I got back but I just figured that you guys didn't want to read about the same tests that I did before so I didn't. At any rate....any other thoughts? Please!?!
Oh yeah, and I pulled off the ECU tonight to check for leaking caps but everything looked okay.
Old 07-23-2006, 10:33 AM
Re: AC/Idle Problem
many cars have the same group size battery or as long as its close and terminal are the same it will work for testing purposes
Old 07-23-2006, 10:42 AM
Igovert500's Avatar
Re: AC/Idle Problem
So, if you don't turn the AC on at all, it holds a steady warm idle at ~700?
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
