Old 07-15-2006, 06:03 PM
atchisbr atchisbr is offline
What causes uneven brake pad wear?
Just completed a full rotor/pad change on my wife's 2000 Alero. When I changed the front left set one of the pads was completely shot (the pad with the wear indicator) but the other was almost perfect. I then changed the other 3 wheels and noticed that all the pads were almost perfect.
So, it appears that the only pad on the entire car to take a beating was the one of the front left with the indicator.
Any clue what might cause this uneven wear? Is the brake system just using the front left for most of the braking?
Bryan
Old 07-15-2006, 09:19 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: What causes uneven brake pad wear?
The problem lies with a sticking caliper. You will either need to rebuild it or replace it with a reman unit. Costs about $60 to $100 depending on the year. Once the caliper is changed the entire braking system should be as good as new.
Old 07-16-2006, 12:55 AM
So just replace the Left Driver side caliper (the one that has the uneven wear) and that should fix it?
Thanks!
Old 07-16-2006, 01:20 AM
jd-autotech jd-autotech is offline
the most common problem is usally the slide pins not being lubed properly but could be a caliper or even a caliper hose
Old 07-16-2006, 10:19 AM
Pontiac Guy
Replacing the caliper should correct the problem. Make sure to lube everything well with brake lube. The slides and mounting bolts where the calipers move and you should eliminate the issue.
Old 09-29-2009, 01:04 PM
plcedziu plcedziu is offline
I have the same problem with my 2000 Alero, but the second time I replaced the caliper, took apart a sticky caliper slide, thoroughly cleaned it, regreased it, and put everything back on. Two months later, the same problem exists. Now what is it? Same drivers side outer front pad going in 2 months.
