Old 07-15-2006, 12:16 PM
odie072 odie072 is offline
Exclamation crankshaft position sensor stuck
hi, new to forum and have a slight problem. I did a search on this and found a little info, but wondering if anyone could give me a little more advice. I have a 97 S10 2.2l 5-speed. I was having a 301code (#1 misfire) so I replaced wires, plugs with no luck so I changed the coil packs and that helped some. The problem still exists so I went to change the CPS but when I started to pull it out it wouldn't come out all the way. The o-ring is still attached to the CPS and I used wd-40 and twisted and pulled for 2 hours with no luck. The shaft is still intact with nothing broken so I tried to push it back in, but it wouldn't go in all the way. Should I "bump" the engine to move the crankshaft and just break the CPS and push the magnet into the engine and not worry about it?? I could move the CPS in and out about an inch. I tried pulling real hard and I could feel the magnet hitting the hole and not coming out. This is a great forum and I'm glad to be a part.
odie072
Old 07-18-2006, 02:07 PM
Blue Bowtie's Avatar
Registered Offender
Re: crankshaft position sensor stuck
I would avoid trying to break it if at all possible.
Old 07-20-2006, 10:38 AM
BLAZERBOY69 BLAZERBOY69 is offline
Red face Re: crankshaft position sensor stuck
odie072
i know this isn't the right forum for this, but i'm having the same problem on my 99 wrangler. i got a #2 misfire code. any help on this would be appreciated
Old 07-22-2006, 03:41 PM
mixmastabob4 mixmastabob4 is offline
I had the same problem in my 96 s10, after i changed the plugs and wires the misfire code went away and i got the one for the cps, so i went to the dealer and got a new one and it fixed it, to get the old one out you do have to bump the engine a few times to line up the big notch to where the sensor is, and with a little bit of playing around with it, it should come out.
Old 07-22-2006, 03:57 PM
mikeII mikeII is offline
Thumbs up Re: crankshaft position sensor stuck
Pull out as far as u can ,then take propain tourch heat slightly causing o ring melt ,then pull out,make sure no fuel or oil present,do not wont no fire ha ha
