Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 07-15-2006, 09:32 AM
DRE484 DRE484 is offline
Timing belt
This may be stupid but ,Im looking at a 88 integra for my son, do these need timing belts replaced,how often,and what happens if it goes out while driving it,and approx.how much to replace. Thanks in advance
Old 07-15-2006, 10:15 AM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: Timing belt
I beileve Honda recomends every 90k. Find out when/if it was last done. If the belt breaks, about 98% of the time the motor is trashed. I'm not sure what a shop would charge to change it but a Saturday with a shop manual and about 25$ for the belt will get it done.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 07-15-2006, 10:32 AM
00accord44's Avatar
00accord44 00accord44 is offline
High on Potenuse
Send a message via AIM to 00accord44 Send a message via MSN to 00accord44 Send a message via Yahoo to 00accord44
Re: Timing belt
A shop is gonna charge you at least $600 to replace the timing belt. Funny you brought this up cuz someone asked a very similar question in another forum. But if you're not that experienced with working on your engine its not recommended you attempt to change your own timing belt because of all the parts involved. Not to say you couldn't if you tried but its very labor intensive and if certain stuff goes wrong (particularly with the crank) then you're gonna cause yourself more headaches. How bad does the current belt sound? Is it constantly making the high pitched screech?
ECNATSISER AL AVIV
Old 07-19-2006, 02:56 PM
Bunger's Avatar
Bunger Bunger is offline
Re: Timing belt
90K is good, but most will last 120K. If the belt does break, there will be a good chance of bending a valve, but 95% of the time the engine is not trash. I've seen 3-4 broken timing belts on b-series motors, a few of them needed some new exhaust valves.
Its also a good idea to replace the water pump with the timing belt, if one goes out, it can distroy a new timing belt. An honest mechanic shouldn't charge more than $450 for a new timing belt and water pump, but you may see as high as $600 from the dealer.
