Old 07-15-2006, 07:52 AM
c8r9x c8r9x is offline
Send a message via AIM to c8r9x
Exclamation grinding gears
how do i fix my 2nd gear so it will stop grinding if i slam it in 2nd it grinds everytime i have to push the clutch in and hold it for a sec for it not to do it as bad do i have to get my tranny rebuilt and how do you know when your clutch is adjusted right how much should i tighten or loosen the cable
Old 07-16-2006, 02:26 PM
h22hatch91 h22hatch91 is offline
Re: grinding gears
i would say u need a new 2nd gear syncro
Old 07-16-2006, 06:48 PM
90sicivic 90sicivic is offline
Send a message via AIM to 90sicivic Send a message via MSN to 90sicivic Send a message via Yahoo to 90sicivic
Re: grinding gears
dont slam it into 2nd.. ??
Old 07-16-2006, 09:20 PM
Re: grinding gears
it grinds if i get my rpms up and shift it grinds it does it even when im driving normal i have to leave it in neutral for a sec so it wont grind
Old 07-16-2006, 09:33 PM
crx2034 crx2034 is offline
Re: grinding gears
I am also having this problem with cy crx. It has a b16 in it. It also has a short shifter. It does this when the RPM's are kinda high. My old crx had a d16 in it and it shifted fine untill I put on a short shifter. It then started to grind when I tried to shift at high RPM's. Is it the short shifter or what?
Old 07-17-2006, 12:37 AM
Re: grinding gears
well just to let you know mine does it sometimes as well.. i have just kinda gotten used to it.. even my buddies car with a rebuild d series si tranny grinds when he throws it into 2nd.. so could just be a common thing?
Old 07-17-2006, 05:49 PM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
Re: grinding gears
change the tranny oil... gm syncromesh...its some good shit...
my dx used to do that...after i changed it with that it wouldnt grind anymore...
as for my si tanny...she is toast...i need to rebuild it, someone who had the car before me must have been really hard on it...
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 07-17-2006, 06:28 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: grinding gears
Yeah your synchros are going.. nothing you can do to stop it except some syncromesh oil.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 07-19-2006, 02:42 AM
Bunger's Avatar
Bunger Bunger is offline
Re: grinding gears
You can try some GM Synchromesh, but really you probably need some new synchros. If you do get around to rebuilding the tranny, scuf up the cones with some 180 grit (use a flapper wheel)... it will help bite the synchro teeth. Also, get rid of the short shifter... it will only kill your trans faster.
Old 07-19-2006, 05:31 AM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
Re: grinding gears
a short shifter doesn't kill ya tranny. go to gear speed for the synchros they will hookya up. and until then just use gm synchromesh.
-tony-
2000 honda s2000
Old 07-19-2006, 03:33 PM
Bunger's Avatar
Re: grinding gears
Short shifters are a leading cause of rapid synchro wear. And yes, Gear Speed does have a good selection... they were the ones that gave me the tip on scruffing up the cones. I've been using their carbon synchros in a number of trans for a little while now, good stuff.
