| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
more boost
ok i have installed a boost controller and a aftermarket boost gauge the right way, i am getting 10psi from the Aftermarket gauge, is there a way to get more boost? like idk 15psi maybe
1991 Talon Tsi automatic, new engine, 16g small turbo, tubuler manifold, pacesetter cat back exhaust, polyuarthen moter mounts, high prof fuel pump, opened up K&N air filter intake |
Re: more boost
what kind of boost controller do you have?
1997 Eclipse GS-T Performance modification:-evo3 16g-K&N Intake-HKS SSQV b.o.v vented-2.5'' Dejon tool blow thru upper and lower-Dejon large smic-GM MAF-MAF Translator-HKS 3" Carbon Fiber Titanium TBE-stock fuel rail-Walbro 190 fuel pump-PE 650cc injectors-Accel Thundersport wires-NGK series 7 spark plugs-1g intake mani/head- Interior Modification:-Autometer Boost Gauge http://www.cardomain.com/id/xTeamRedLine23x |
Re: more boost
ah I don't know, i bought it from turbonetics.com and i have had it for aleast a year and then put it in when the car got going, it is a manule controller
Re: more boost
Just turn the damn thing up.
Caleb vanilla gorilla '99 Spyder 2.4 5-speed - Red/black,14b,slow '96 Eclipse GST 5-speed - Paint www.myspace.com/ballsoutperformance |
Re: more boost
how do you have the boost controller hooked up?
Re: more boost
i have it hooked up to the wastgate that is on the turbo, and then hooked up to the J pipe, the is a vacume line that is going to a sensor that is on the maf, and that vacume line was/is hooked up to the J pipe through a t connecter
Re: more boost
this is what they show me
Re: more boost
my instuctions are diffirent, they just show the whole turbo and the wastegate act, and explans how to hook it up
Re: more boost
basically the mbc has to go between the vac line that goes to th wastegate, basically the mbc lies to the wastegate by only allowing a certain amount of pressure to the wastegate (because the wastegae has a spring set for a set boost level).
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff. http://www.ratemydsm.com/member/ez1286/?member=ez1286
Re: more boost
Im planning get a MBC, What brand is the best ? thanks
GM FOR LIFE !! NEW 1997 Camaro z28 6 speed illa never going back to import , but killa alway be nice to any DSM he saw ![]() looking for 2002 Trans Am LSX UPGRATE 2010 !! 97 Camaro Z28 95 camaro lt1 1992 Pontiac Firebird v6 auto -sold - Pony 1998 Mustang GT 4.6L Manual. Black 1995 Eagle Talon TSI AWD Turbo manual R.I.P 1994 Mitsubishi Eclipse Manual gray -Sold 1997 Mitsubishi Eclipse RS Auto White - Sold |
Re: more boost
I would recommend against turbo xs. Just my opinion though.
But its not like its a very high tech part, some people make thier own. So its mostly just preference, I've heard good things about Joe P.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM. 18 Inch chrome rims In closet AEM Fuel Rail, SS Lines, 1997 TSI AWD Diamonds Are 4Ever 12.7 @ 107 http://i83.photobucket.com/albums/j2...y/DSC00461.jpg |
Re: more boost
JoeP
simple, cheap, works well
now - 2000 civic soon - 2002 is300
Re: more boost
I'll third the Joe P. Always worked well. I keep one around as a backup in case my EBCs fail.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
Re: more boost
I have that same b/c i found that if you turn it down that it will raise the boost level. They are crap i got mine for free but it has been a pain in the ass the hole time ive had it. The most ive got out of it on my 14b is 17psi on a really cold day so good luck
MODS , 2g pistons, cyclone intake manifold, ported 1g head, 60mm tb, greddy type s bov, apex-i n1 exhaust , ngk spark plugs, 3 angle valve job, autometer boost/vac, autometer air/fuel ,autometer oil pressure ,cross drilled rotors ,turbonetics boost controller ,air filter ,remove dump tube, 14b turbo and the ac still doesn't work and its been almost 3 years |
Re: more boost
You get it working yet matt50317? also, what are you getting for an ET time?
The last question doesn't really relate to the topic, i'm just wondering.
