Go Back   Automotive Forums .com Car Chat > Honda > Del Sol
Old 07-14-2006, 07:48 PM   #1
BlakeWood
Gauges
I recently installed some reverse indiglo gauges in my '95 Del Sol S. I spliced and soddered them to the aux. lights. The gauges light up perfectly, and the gas gauges and engine temperature work fine; however, the tach is sticky and won't go smoothly, and the speedometer has gone crazy. The speedometer won't read correctly. For some reason it always shows that I'm going faster than I actually am. Any help y'all could provide would be greatly appreciated.
BlakeWood is offline   Reply With Quote
Old 07-14-2006, 09:57 PM   #2
AudioGuy93DelSol
NA is Best!
AudioGuy93DelSol's Avatar
Send a message via AIM to AudioGuy93DelSol
Re: Gauges
Possibly the face is rubbing against the tach needle. As for the speedometer, do you mean it's jumping around? If it's just reading fast it's probably becuase the gauge faces are miscalibrated. Where did you get them from?
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
AudioGuy93DelSol is offline   Reply With Quote
Old 07-15-2006, 03:40 PM   #3
BlakeWood
Unhappy Re: Gauges
I made sure that the needles weren't rubbing the faces and that the rods that the needles were on weren't bent. How could the gauge face be miscalibrated? I'm sure that's not the case though. I got them from D1 Zone.
Old 07-15-2006, 10:47 PM   #4
AudioGuy93DelSol
NA is Best!
Re: Gauges
By miscalibrated I meant that they screwed up printing the numbers on the face. Did you play around with the needles while you had the cover off? I've heard that can damage them and that's the only thing I can think of that would cause these problems.
Old 07-16-2006, 10:31 AM   #5
BlakeWood
Angry Re: Gauges
I doubt that they misprinted the numbers on the gauge face because the numbering looks just like the old gauges. As for the needles, all I did was pop them off, put on the new faces, then pop them back on. I tried not to mess with any of that stuff too much because I'm not 100% sure how it all works.
And here's another boggling thing. The tach isn't sticky when I have the clear plastic front off of the gauge box. It didn't make any sense to me, so I looked to see if the plastic face was rubbing the needle, and it wasn't. I looked to see if the plastic front, in any way, affected anything with the tach, and it didn't. I just don't understand why the stupid things won't work now.
Old 07-16-2006, 12:02 PM   #6
AudioGuy93DelSol
NA is Best!
Re: Gauges
Maybe check the wiring harness behind the guage cluster. Make sure those 2 big plugs are in tight. That's the only other thing I can think of.
Old 07-16-2006, 12:35 PM   #7
BlakeWood
Question Re: Gauges
Everything's plugged in nice and snug. Do you know if there's a way to like reset the gauges (not odometer), like a recalibration for the needles type of thing.
Old 07-16-2006, 05:20 PM   #8
AudioGuy93DelSol
NA is Best!
Re: Gauges
No, noting that I know of. And all these problems started right after you put the faces on? You haven't dont anything to the ECU correct?
Old 07-17-2006, 05:41 PM   #9
BlakeWood
Re: Gauges
Here is exactly what I did:
removed the gauge box from the dash by unplugging and unscrewing everything
removed the old gauge faces
put on the new gauge faces
soddered the new gauges to the auxillery lights switch
put everything back together
Old 07-17-2006, 10:46 PM   #10
AudioGuy93DelSol
NA is Best!
Re: Gauges
I took a working dizzy off once and put it back on the next day and it didn't work anymore. Random breakage I guess. I really can't think of anything else other than the cluster itsself is messed up.
Old 07-18-2006, 11:15 PM   #11
BlakeWood
Re: Gauges
Do you think if I brought it to a mechanic that maybe they could find and fix whatever's wrong? It's pretty annoying to have malfunctioning gauges, and it's going to suck when I'm going 60 but think it's 45 and get a ticket.
Old 07-18-2006, 11:44 PM   #12
AudioGuy93DelSol
NA is Best!
Re: Gauges
You'd probably have to replace the cluster. I doubt your local mechanic would be able to fix it. Maybe you could take it apart and see if you can find anything that looks wrong. It's worth a shot. If all else fails, passwordjdm.com has del Sol SiR clusters on sale.
Old 07-18-2006, 11:57 PM   #13
94SolGrl
Honda GODDESS/Global Mod
94SolGrl's Avatar
Send a message via AIM to 94SolGrl Send a message via MSN to 94SolGrl
Re: Gauges
I'll go ahead and shoot this thing in the forehead to put it out of its misery.
When you popped the needles off you decalibrated them. Had you played with them a bit you would have noticed that they are spring loaded. If you manually move the speedometer up, it goes back to 0. When you popped the speedo needle off, the post that it mounts to was allowed to spin all the way down (ever wonder why there's that little perch for the speedo needle to sit on? It keeps it from rolling all the way down). With the speedometer needle decalibrated, your ECU is confused. The motor's speed sensor is sending it one bit of info, the gauge is sending it another. Consequently, it doesn't know what to tell the tach. You also probably bent the tach post when you popped the needle off. The entire gauge cluster mechanism is mechanical. One thing's off, it's all off. It's also very delicate.
The bad news:
Your cluster is f'd, and very few shops will work on them. Usually only honda dealerships will, and they report it to carfax as an odometer discrepancy. To avoid that, go junkin/ebaying and try to find a new cluster with close to the same miles.
The good news:
del Sol S model clusters are cheap.
And the SiR cluster will NOT work. You have an S model. The positions for the needles will be off. It will say you are at 3500 when you're actually at about 2500 (rpm) because the SiR cluster has more numbers on it. Get another S model cluster and get gauges that don't require removal of needles. (usually the hole in the middle of the gauge is big enough to slide it over the needles).
And they all lived happily ever after. The end.
~*Emily*~
1995 Nissan 240SX - S15 whore
HOW TO POST PICS!
94SolGrl is offline   Reply With Quote
