Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 07-14-2006, 06:19 PM
TeamRedLine23's Avatar
TeamRedLine23 TeamRedLine23 is offline
Send a message via AIM to TeamRedLine23
I need help with a boost controller...
I did a search and read all of them but looked at all the pictures but I still dont understand. I have a perrin bc. I have it hooked up like this. from the turbo compresser to the bc then to the wastegate. I have hte perrin instuctions and from what I understand from the instuctions thats how to do it. I cant boost more the 10 psi. thanks
1997 Eclipse GS-T
Performance modification:-evo3 16g-K&N Intake-HKS SSQV b.o.v vented-2.5'' Dejon tool blow thru upper and lower-Dejon large smic-GM MAF-MAF Translator-HKS 3" Carbon Fiber Titanium TBE-stock fuel rail-Walbro 190 fuel pump-PE 650cc injectors-Accel Thundersport wires-NGK series 7 spark plugs-1g intake mani/head-
Interior Modification:-Autometer Boost Gauge
http://www.cardomain.com/id/xTeamRedLine23x
Old 07-16-2006, 07:55 PM
Talont28 Talont28 is offline
Send a message via AIM to Talont28 Send a message via MSN to Talont28 Send a message via Yahoo to Talont28
Re: I need help with a boost controller...
Well Its suppose to t into the line that goes to your bov and the wastegate...thats it
Jesse
Its a Dsm thing...
<img src="http://www.dsmtuners.com/gallery/data/500/44010Pcdv0154-thumb.jpg">
Old 07-16-2006, 09:48 PM
LouieAWDTSi's Avatar
LouieAWDTSi LouieAWDTSi is offline
plymouthlaser.com has great directions. I used the compressor elbow fitting and the wastegate.
--the Cruiser-->97 Spyder GST 5sp ---3 inch exhaust, boost/vac gauge, mbc, greddy turbo timer, greddy fmic, greddy type S BOV, 17in wheels
--the DD-->99 ACURA 3.2 TL
--Sold 92TSi AWD, 6-bolt, auto, evo 3 gt turbo with supporting mods
Old 07-16-2006, 10:02 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Jesse
thats the dumb way. run it right off the turbo elbow. make sure you have it installed the right direction. if you post a link to the specific boost controller you have that would help. do you know if its a ball and spring or a bleeder type?
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 07-17-2006, 07:05 PM
He has a 2g there is no elbow.....read b4 insulting others...
Jesse
Its a Dsm thing...
Old 07-23-2006, 12:40 PM
thanks for all your help, i had the boost controller pointed in the wrong direction like a dumb ass.
1997 Eclipse GS-T
Old 07-24-2006, 05:33 PM
Jesse
yea whatever jackass.
tap it in anywhere but the bov line. tapping in there will cause the bov to stay partway open because the boost controller is a boost leak. a very small one but they all have a bleed hole so that after they close the pressure can escape from the mbc to wastegate line so it can close. bleeder mbcs leak even worse since all they are in a calibrated leak in the wastegate line to delay the response
-1stGenRocks-
