Go Back   Automotive Forums Car Chat > Toyota > Supra > Maintenance
Maintenance Have questions? Find answers. Help out fellow Supra owners.
Old 07-14-2006, 06:07 PM
columbomd columbomd is offline
Question nonoperational supra
i have a 1986.5 supra that has been sitting for two years .what needs to done to make it operational again:what kinds of shops do this work and how much could something like this cost?
columbomd
Old 07-15-2006, 09:15 PM
TcmaBoy's Avatar
TcmaBoy TcmaBoy is offline
AF - Advisor
Re: nonoperational supra
I guess you need to start by changing all the fluids, the battery, drain the gas tank, fill it with fresh gas, change the fuel filter, plugs and wires, and change the battery. Once you have done all this then give her a crank. It will either start or it won't. You will have to troubleshoot from there. A shop can end up costing a lot of money. If you have a daily driver then I would say that you have a good car to learn on.
Don't you SAS me boy.
Please wheel responsibly.
http://www.treadlightly.org/
Old 07-16-2006, 10:00 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
good post^^
In addition, I might suggest before doing this work, pull the plugs, squirt about a teaspoon of ATF fluid down into each cylinder and try to turn the engine over by hand, that is, use a socket and ratchet on the crankshaft pully. If it moves, turn it over a few times by hand. This will distribute the oil on the cylinder walls and help ensure the engine is not seized by rust.
If the car was stored in a reasonably dry location, even if it's outside, the engine should not be stuck. If it was parked in a Florida saltwater swamp for 2 years, you may have a problem.
