Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 07-14-2006, 04:58 PM
95tahoe190k's Avatar
95tahoe190k 95tahoe190k is offline
95 tahoe rearend gov-lock carrier is loose 1/2" end play in axel's
#1 how do i get the gov-lock apart ,,? #2 would it be cheaper to just buy a used rearend ?I opened it and the pos gov-lock carrier is flopping around. My diff cover has the magnet full of steel probly the carrire barrings ...Please someone paint me a better picture right now its looking grim
Old 07-14-2006, 06:50 PM
maxwedge maxwedge is offline
A990 racer
Exclamation Re: 95 tahoe rearend gov-lock carrier is loose 1/2" end play in axel's
Eaton Locking diffs are not repairable, you need a replacement unit, consider some of the better A/M locking or posi units.
Old 07-17-2006, 02:58 PM
Just answer the 1st ?uestion Please
Old 07-19-2006, 10:57 AM
Who said anything about an Eaton locking diff ? this is a gm product gov-bomb junk its not a locker ...My problem is i cant get it out , i plan on getting an open carrier i just want to get it out so i can see the damage , inspect the carrier mount i can't find the gov-lock tool.Please help
Old 07-20-2006, 06:39 AM
A990 racer
Angry Re: 95 tahoe rearend gov-lock carrier is loose 1/2" end play in axel's
Are you kidding, I said it is not repairable, Eaton does not make individual parts for the unit!!!!!!
Old 07-20-2006, 07:11 AM
Shortbus Shortbus is offline
Blah blah blah
Send a message via AIM to Shortbus
Maxwedge is right, there is nothing serviceable in the governor and taking it apart will do you no good, once the GM gov-loc goes bad it's throwaway. GM sells them as an assembly, as well as other aftermarket companys that buy direct from dana/spicer corp.
Old 07-20-2006, 04:45 PM
Ok 1st im sorry for the confusion .Im not trying to take it apart i just want it out the whole carrier.I took out the retaing bolt that holds the pin between the axels thats out np the pin fell right out.Now i cant find the tool to get the carrier apart to remove it from the rearend. I can't get the gov-lock apart to get to the spide gears, to get to the c-clips,to pull the axels out of the carrier. there is a special tool that presses 2 pins out so im told i can't find any info @ all on it i just want this carrier out of my rearend thats all ..... sorry again for any confusion ...... ps help me get this carrier out.
Old 07-21-2006, 07:20 AM
Blah blah blah
Where I work now I frequently use Dana's website to order parts and print complete service manuals for Heavy duty on highway transmissions and differentials I noticed they do have a section for light duty applications with diagrams and literature. Hopefully if no one answers this link will help you.
http://www2.dana.com/expert/wc.dll?cvsp~Depdf~5~AXL~
I personally have never messed with a differential as its a bit over my head, and I never have had the tools needed to properly set one up anyway.
John
