92 dodge ram van b350 5.9L v8 problems Misfires and wont accelerate
hi
my friend just changed my plug wires and spark plugs on my 92 dodge ram van now the van wont drive without misfiring? is it possible my plugs are malfunctioning? i tested the plug wires with an inline tester and they all work good. also i did a check engine analysis and i got these codes 37 Shift indicator light failure, 5-speed OR part throttle lock/unlock solenoid driver circuit (87-89) OR solenoid coil circuit (85-89 Turbo I-IV) OR Trans temperature sensor voltage low (1995 and on; see NOTE 2) 45 Turbo boost limit exceeded (engine was shut down by logic module) |
Re: 92 dodge ram van b350 5.9L v8 problems Misfires and wont accelerate
i dont know if those codes are defined correclty because i got the definition off the internet from this site
http://www.allpar.com/fix/80s-codes.html |
I put the plug wires on like this?
is this right http://autorepair.about.com/library/...bl-fo-8487.htm |
i took the van to a shop they pluged in the plug wires kinda like that link above but it was one off seems the firing order started with 8 instead of 1 so 84365721 wierd but it runs great now 8 is where the 1 is on this diagram http://autorepair.about.com/library/...bl-fo-8487.htm |
