Old 07-14-2006, 10:45 AM
98blazerRI's Avatar
98blazerRI 98blazerRI is offline
Cannot screw Dist cap to Dist
Hello all, have a minor problem... Truck was running terrible, mostly on wet humid mornings, so after reading the threads on here I decided to check my cap, rotor and wires... Well after pulling the wires out of the cap I noticed they were green... After changing everything the Blazer runs fantastic... But, now on the Dist. I can not screw the cap on tight because the screw hole is broke. Has anyone had this problem and is there a fix...
Thanks
Old 07-14-2006, 10:55 AM
SComp23 SComp23 is offline
Re: Cannot screw Dist cap to Dist
Thanks
This is a common problem unfortunately,GM uses so much damn loctite, that the crap builds up on that thing ring, and when you try to put the screw back in it cracks. This happened to me as well, and after becoming furious that I was told I would need a new distributor to get a new screw hole, I JB Welded the cap to the distributor.
Old 07-14-2006, 11:03 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Use silicone adhesive around the edge of the cap and secure it that way.
Make sure the surfaces are clean before doing it and it will stay put.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 07-14-2006, 11:08 AM
98blazerRI's Avatar
A NEW DISTRIBUTOR!!!!! That's crazy... So did you just spread the JB Weld around the outside if the entire cap or should I just put a dab right where the hole is?
Old 07-14-2006, 11:13 AM
98blazerRI's Avatar
Is the Silicone idea better?
Old 07-14-2006, 12:01 PM
BlazerLT's Avatar
AF -Advisor
not permanent so you can replace in the future.
Old 07-14-2006, 12:47 PM
98blazerRI's Avatar
Sounds Good BLT.... Will give it a go.... Have to say this forum has saved me some $$$$$$$$
Old 07-14-2006, 01:34 PM
BlazerLT's Avatar
AF -Advisor
oh for sure, saved me 1000s.
Old 07-15-2006, 02:08 AM
534BC 534BC is offline
Put a longer bolt in it with a flat washer and nut below the broken housing.
Old 07-16-2006, 09:17 PM
dwitczak dwitczak is offline
I used zip tie on it. seems to do the job.
Old 07-17-2006, 04:47 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
i agree with 534 bc
