Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-13-2006, 10:30 PM
cottonballs43's Avatar
cottonballs43 cottonballs43 is offline
Send a message via AIM to cottonballs43
98 GST Engine Grinding Noise
I need help pin-pointing this noise. Its coming from the right side of the engine bay where all the belts are. Sounds like a bearing going bad, I took the belts off so the alternator or water pump would not spin, the sound was still there. It happens as soon as you start the car and doesn't go away until you shut it off except for if the car goes under 900rpm then it magicly goes completly away. Under load the noise isent too bad, like I said just sounds like a bad bearing but sitting at idle if you rev the engine it gets very loud and raspy. I work at a shop, we all checked it out and have come up with nothing other than maybe a cam shaft bearing going bad (probeing with a stethoscope leads me to believe its not though), although I have tested the alternator and water pump I'm still not going to rule them out. The idler pully and tensioner pully don't seem to be what's making the noise when we probed it. I just dont want some pully to freeze up and heat my timing belt or anything like that. any advise would be great as well as questions. The car has about 140,000 miles on it, 5 speed trans, front wheel turbo, all the belts look fine.
P.S. The list of stuff below is from my old gs-t, this one I just bought about a month back, has no modifications at all and only one previous owner
'98 Eclipse GS-T
BIG T-28 Drag Turbo
Intake System
Extreme Turbo-Back Exhaust
Greddy Type S Blow Off Valve
Larger Intercooler Piping
VIS OEM Carbon Fiber Hood
Boost Controller
Upgraded Fuel Pump
Stage 3 Racing Clutch
Turbo Timer
Air/Fuel and Boost Gauges
Intrax Lowering Springs
35% Window Tint
Old 07-13-2006, 11:12 PM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
Re: 98 GST Engine Grinding Noise
how do you test a water pump? isn't it good or bad, nothing in between?
Old 07-13-2006, 11:25 PM
Killa's Avatar
Killa Killa is offline
Dude post in the right forum, dont give admis here a hard time, moving topic around.
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 07-13-2006, 11:30 PM
the water pump it self is working fine, but that doesnt mean it doesnt have a worn bearing causing that anoying grinding hum i'm hearing
'98 Eclipse GS-T
BIG T-28 Drag Turbo
Intake System
Boost Controller
Upgraded Fuel Pump
Turbo Timer
35% Window Tint
Old 07-13-2006, 11:33 PM
how is this not the right forum?
Automotive Forums > Mitsubishi > Eclipse/Talon/Laser >
'98 Eclipse GS-T
BIG T-28 Drag Turbo
Intake System
Boost Controller
Upgraded Fuel Pump
Turbo Timer
35% Window Tint
Old 07-14-2006, 12:05 AM
gstclips gstclips is offline
Send a message via AIM to gstclips
he was refering to the sub-forums at the top of the page, this thread belongs in the diagnosis sub-forum...
THE OFFICIAL AF PIMP! - love EclipseRST[Banned]
1997 Gs-t Eclipse
6 bolt + other toys
Currently 295whp
Old 07-14-2006, 12:14 AM
well had I have seen that I would have most certainly put the post under the right forum, other than that do you have any suggestions for the problem I'm having with my car
'98 Eclipse GS-T
BIG T-28 Drag Turbo
Intake System
Boost Controller
Upgraded Fuel Pump
Turbo Timer
35% Window Tint
Old 07-14-2006, 12:17 AM
Killa's Avatar
Does the sound go away , after you drive around a bit ?. Is the sound only heard when you revert the engine, is the sound gone after thirst gear ? if you can record a clip, what the sound like, that will be great, or call me tomorrow ( message me for phone #). I will tell you what the noise is.
GM FOR LIFE !!
95 camaro lt1
Old 07-14-2006, 12:32 AM
The sound stays from start to finish. its a low huming sound when the car is idle, when you rev the engine it gets louder and very raspy although when your in gear and the rpm's are just as high it just sounds like it does while the car is idling and not so loud or raspy. It makes this noise in any gear although harder to hear because of the road noise. I'm going to try and get a video clip tomorrow
'98 Eclipse GS-T
BIG T-28 Drag Turbo
Intake System
Boost Controller
Upgraded Fuel Pump
Turbo Timer
35% Window Tint
Old 07-14-2006, 12:54 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Have you had the timing cover off recently? I bet its something rubbing on it.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 07-14-2006, 01:12 AM
I had the upper timing cover off, I actually already looked to see if anything might be rubbing against the cover but didnt see anything, none of the belts look like they've been wearing against anything either. I'll look again though tomorrow just to be sure.
'98 Eclipse GS-T
BIG T-28 Drag Turbo
Intake System
Boost Controller
Upgraded Fuel Pump
Turbo Timer
35% Window Tint
Old 07-14-2006, 01:26 AM
Thor06's Avatar
Jizzed In My Pants
Low on the power steering fluid?
Old 07-14-2006, 07:12 AM
4g63gst20 4g63gst20 is offline
Send a message via MSN to 4g63gst20
i think it's the altenator, when i first got my gst i was freaking out because it started making a grinding noise, at first i thought it was something in the engine, but my dad kept telling me it was the alternator, it was was still charging the battery and everything but i guess the bearing went bad, end of the story we replaced the alt. and noise was gone.
-MODS-
Autometer Boost,Oil Presure,And Water Temperature Gauges./Geddy Turbo Tmer/Eibach Sportline Springs Matched With Adjustable Iluminas 4 Corners/Konig 18" On Nitto Extreme 555/ACT 2100 PP with Street Disc/Extended Push Rod/Urethane Motor Mounts/XS Power FMIC. 28X10.5X3.5/Greedy Type RS BOV/ evo3 16g Turbo/MBC At 18PSI/Bian Crower 272 cams/SAFC2 With 510cc Injectors/Walbro 190 FP/
1/4 mile=14.3@103MPH
Old 07-18-2006, 12:05 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
What all have you checked with a stethoscope? Is it a grinding noise like a bearing, or more like a low growl? I'm guessing alternator bearing or something with the PS pump (low fluid, bad bearing, etc)
Edit: After re-reading your post and realizing that those could not be the problem (I'm an idiot), the only other bearing that could cause a noise like that would be the water pump or idler pully for the timing belt. And if you think that it could be the cams making that noise, you'd better pull them off and check it out asap before you ruin a head (if you didn't already).
95 Talon TSI AWD
97 Eclipse GST
Old 08-19-2006, 02:07 AM
well...... i was positive it was the water pump because when i recently took off its belt the noise was completely gone. pulled everything off, replaced the water pump, timing belt, auto tensioner, tensioner pulley, idler pulley and ps pump also. everything's back together and runs fine but the noise is still there! i was pissed since i knew it was the water pump. the only thing i can think is that maybe its the actual crank and that it only makes the noise when the alt, ps, wp, and ac are hooked to it because of the strain they put on it. other than that my buddy brandon who has a first gen said he had heard of a problem where the crank pulley some how comes apart and starts making a weird grinding noise? while i had the wheel off i could really notice that the noise is extremely loud near the crank pulley.
good news is i have all brand new belts! im going to check it out again tomorrow when im a little less.. mad as hell
'98 Eclipse GS-T
BIG T-28 Drag Turbo
Intake System
Boost Controller
Upgraded Fuel Pump
Turbo Timer
35% Window Tint
