Old 07-13-2006, 09:19 PM
crx2034 crx2034 is offline
failed emissions again HELP
Well my jdm crx sir just failed emissions again. I changed the cat, plugs and had the rest of the car checked for timing and fuel pressure. It all checked out OK. I ran the car with no air filter because the one i had was horribly clogged and I could not find one that fit. I tried integra, del sol and all civics and none were the same size as my crx. It did do better than the first time but not well enough. The hydrocarbos were as follows
1st test 2nd test maximum to pass
Hydrocarbons: 3.20 1.28 1.00
Carbon monoxide 56.61 37.33 12.00
It has all the emssions controls needed to pass. Whoever had it first made it legal and has everything like o2 sensors and stuff. I was told it is running rich. ANY AND ALL INPUT PLEASE.
Old 07-14-2006, 11:31 AM
Re: failed emissions again HELP
can any one help?
Old 07-14-2006, 01:10 PM
bionictony's Avatar
bionictony bionictony is offline
Send a message via AIM to bionictony
check the oxygen sensor and ecu computer?
Old 07-14-2006, 03:23 PM
2poor2tune's Avatar
2poor2tune 2poor2tune is offline
Send a message via AIM to 2poor2tune
yeah replace it if it looks clogged
Old 07-15-2006, 01:47 PM
Ok guys, i just looked at the ECU because i had i wierd feeling. It turns out that I have a 1st generation spoon ECU with an adjustable vtec controller. The vtec controller is a knob type and not digital. How much more fuel does the spoon ECU dump? I was told I was running rich. What ECU do i need to get to run right. It is a 1st generation b16. Please help anyone. I live in phoenix az and just need to borrow the ECU to do my emissions testing. PLEASE HELP PEOPLE
Old 07-15-2006, 07:09 PM
Hybrid1990crx's Avatar
hydrocarbons are unburn fuel, which would be your fuel problem. Then can be caused from a missfire or a lean mixture in general, but your o2 reading would then be low.
Carbon Monoxide should be getting changed from the catalyst into carbon dioxide.
You might want to change your cat.
You're fule problem could easily be coming from the ecu, try to get a stock pw0 or pr5.
If anything not having a air filter is going to lean out your mixture.
In PA if you have spent up to 150 dollars in replacement parts to get your car to pass you can ask for a waiver which will be good until the next year.
Old 07-19-2006, 03:28 PM
Bunger's Avatar
Bunger Bunger is offline
If you're in Phoenix, you're in luck. Contact Joe at Hasport, I'm sure he can get you the right ECU for your swap (PR3 or PW0). Hasports number is 602-470-0065.
Old 07-20-2006, 03:44 PM
thanks dude, however, it is not a swap but a jdm crx from japan and all. i will call tomorrow morning and see if they can help. I just need to borrow the ecu for an hour or so.
Old 07-20-2006, 05:00 PM
2poor2tune's Avatar
hey. here is what my friend did with your motor in his car and his chipped ecu by locash. he bought a udjustible fuel pressure regulator and then turned it down but not to much and he passed just today. make sure you dont go to low.
Old 07-20-2006, 05:06 PM
Bunger's Avatar
Joe at Hasport IS locash... =)
