Old 07-13-2006, 10:07 PM
kevinthenerd kevinthenerd is offline
Wheel/Tire idea
Often the problem with modifying ride height in the suspension is to restore the proper geometry (especially camber), and this step is often overlooked by those who just slap lowering springs on their car. I got to thinking about something, though. Another way to lower the center of gravity of a car is to put smaller wheels on it, and with no change to the springs, it wouldn't change the suspension geometry (but it might change the optimal geometry, though, which is something I'll have to investigate on paper some more). Smaller wheels also simulate a shorter gear ratio, and they provide less rolling inertia. Do people sell aftermarket rims that are something like 10 or 12 inches in diameter but that are really wide?
The only problems I can see (that aren't already associated with a lowered ride height) is that you're going to have difficulty fitting the suspension uprights and brakes into the smaller area, and the spedometer will have to be adjusted. You'll also have problems scaling bumps, so ride comfort will suffer. The tires will have less time to cool, but increased width would more than make up for this because a wide tire uses its patch more efficiently. Other than that, it seems like a cheap modification for what you'd get.
Old 07-13-2006, 11:21 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Wheel/Tire idea
Its not really going to change alot other than the fact you'll look like a mexican. The center of gravity will be lower, but your still riding on squishy suspension.
Old 07-14-2006, 01:11 AM
Re: Wheel/Tire idea
You don't think it'll help acceleration in underpowered cars?
Old 07-14-2006, 01:40 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: Wheel/Tire idea
Most cars come with the smallest size wheel that will fit the car, the rest come with bigger wheels in order to use lower profile tyres.
While a lot has to do with image, the lighter wheel and lower profile tyre will also offer greater benifits to performance than useing a smaller wheel and tyre.
I do know of people who use smaller wheels on race cars, but they tend be a last ditch effort, after lower suspension has been fitted, along with shorter gear ratios etc, to get that little extra bit of potential performance out of the car.
Old 07-14-2006, 08:07 AM
Forunn Daberator
Re: Wheel/Tire idea
Accelleration on take off or wanting to pass someone on the highway doing 75?
Old 07-15-2006, 03:26 AM
Rufe Rufe is offline
Re: Wheel/Tire idea
A couple of issues to consider...
1. smaller tire, less air in tire, less load rating.
2. smaller diameter, wears much faster, overheats easier.
You are correct in wanting to lower the CG. But do not overload the tires in the process.
Old 07-15-2006, 07:50 AM
mazdatech177 mazdatech177 is offline
Re: Wheel/Tire idea
yeah, youll probably end up smoking the wheel bearings prematurely, and as was stated above... itll look freakin' retarded
Old 07-15-2006, 12:06 PM
Re: Wheel/Tire idea
... increased width would more than make up for this because a wide tire uses its patch more efficiently. ....
Can you explain your reasoning a bit more on this point.
Additionally, performance is a balancing act. Add here, take away there.
Have to agree with you in theory, a smaller tire diameter is like getting free power (better acceleration), however, you lose gas mileage, top speed and tire wear.
If you are running a quarter mile, you can tune the car with gearing to get peak engine power at the end of your run. Peak HP does little good if you can't get the engine into that rpm range in time.
Old 07-15-2006, 02:45 PM
Black Lotus's Avatar
Black Lotus Black Lotus is offline
Re: Wheel/Tire idea
but it might change the optimal geometry, though, which is something I'll have to investigate on paper some more----.and they provide less rolling inertia. Do people sell aftermarket rims that are something like 10 or 12 inches in diameter but that are really wide?---- but increased width would more than make up for this because a wide tire uses its patch more efficiently. Other than that, it seems like a cheap modification for what you'd get.
You sound like you want to go to REALLY small dia. stuff, so I'll put in my two bits worth.
If you keep the same offset rims, you retain the same suspension geometry from the front plane view as well as the side plane view. If you change the rim offset, the geometry as view from the front plane changes and everything is up for grabs. If your car is FWD, you HAVE to carefully consider the rim offset.
Were you to find some rims with the same offset, the smaller overall dia. tires could cause you some stability problems. You lose some of the "pneumatic trail"--wider tires have a different contact patch than narrow tires. Their footprint is shorter, as viewed in the side plane. This fore and aft length is called the Pneumatic Trail as opposed to the mechanical trail associated with caster, kingpin offset, etc.
Both trails are associated with the tire wanting to run straight even if disturbed by a side force or steering input.
The pneumatic trail is the "real " feel you get at tire breakaway and the steering will get heavier then lighter feeling as the tire starts to slide. With mechanical trail, the steering just gets heavier and tends to swamp out what the tire is trying to tell you. I suspect that you would end up running more caster to regain directional stability, then have a loss of steering feel as a byproduct.
Then again your car may be so slushy feeling no matter what you do, that my little contribution here is completely redundent.
But hey, you have to consider all the angles.
As a final point, do not underestimate the importance of "looks" and "style".
Old 07-15-2006, 04:06 PM
Re: Wheel/Tire idea
Yeah... totally ghetto Mexican
Old 07-15-2006, 09:29 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: Wheel/Tire idea
90% of the time smaller wheels won't clear the stock brakes.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
