Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-13-2006, 08:41 PM
wanaplay134 wanaplay134 is offline
Send a message via AIM to wanaplay134
lifter problem
i rebuilt my motor. yes a stroker anyway i bought a stage 2 head and all that i put about 30 miles on it and it just started to sound terrible so i thought i bent a valve or something. the shop that built my motor took care of everything and found that no valves were bent but the lifters were all impacted with oil and wasnt flowing the oil through them does anyone know why this should happen and why that fast or anything to watch for. im runing stock lifter but now im going to order the 3mm so that i shouldnt have to worry any more but i had 140,000 on my last motor and that never happened
1992 eagle talon tsi awd
xtd stage 3 six puck/apexi 3' downpipe and exhaust/ngk plugs/taylor thunderbolt wires/manual boost controller set at 20psi/walbro 255 with rewire/autometer boost gauge/turbo xs rfl blow off valve/arp headstuds/ to4b vtrim turbo/dnp tubular manifold with o2 housing and tial 38mm wastegate/eagle rods/ross pistons/acl bearings/arp rod bolts/arp main studs/aeromotive fuel pressure regulator and all stainless lines/aem fuel rail/slowboy street front mount kit
Old 07-13-2006, 08:55 PM
SLoe's Avatar
SLoe SLoe is offline
Re: lifter problem
You mean collapsed lifter? Look it up.
Maybe they weren't soaked in oil before they were installed. Maybe they were old and dirty. Lifters have very small passages and tight tolerances. IDK BUT .................................................. ......
You double threaded BTW
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 07-13-2006, 10:55 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: lifter problem
Well if you just had the motor rebuilt when did you change the oil? What kind of filter did you use? They could have been clogged with tiny pieces of metal if you didn't change the oil soon enough or if you used a shitty oil filter.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 07-14-2006, 09:15 AM
Re: lifter problem
well i used a k&n oil filter and the whole engine only had 30 miles on it so i wouldnt change the oil for at least 1000 break in miles and then every 3k.
Old 07-14-2006, 11:00 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: lifter problem
Bad strategy. Search for my previous posts about oild changes during break-in.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
