Old 07-13-2006, 08:14 PM
papasmith papasmith is offline
Cleaning Injectors or Not
I have a 3.4 engine which was idling roughly and after eliminating most other problems I strongly suspected a poorly functioning injector on the number 1 cylinder. Since there was a faint smell of gasoline, I additionally suspected an O ring failure. Because of this, I took out the injector rail with the injectors and am going to replace all the O rings. Since I have the injectors off, I am considering cleaning all the injectors off of the car. I suspect that the offending injector is plugged up from sitting too long. I know there are some fuel injector cleaning kits but I would like to get input as to which of the following is the best way to proceed.
1) Reinstall injectors and use an injector cleaning kit designed for use while the injectors are on the car. (Where is the best place to get these?)
2) Spring for an out of car cleaning kit which I can get at Advance Auto for around $268.00. I know this option is expensive but, I can use it for my other cars as well. I understand this method works better than on car injector cleaning. If there is a better place to buy these kits let me know.
3) Send injectors to a place such as the "injector Perfector" to have them cleaned for about $20.00 apiece. Disadvantage is the turn around time.
4) Use a method I have seen on the internet where a small voltage is administered to injector, small amount of solvent is put into the injector and and compressed air is blown through when the injector is activated. If this is advised, does anyone have detailed instructions how to do this.
5) Buy one injector and hope I don't have any problems with the others.
6) Put in injector cleaner and hope for the best. (heard this method is only marginaly successful at best)
6) Should I do something else?
Thanks for your advice
Old 07-13-2006, 08:59 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: Cleaning Injectors or Not
I think a spray can of pressure cleaner via the rail or cleaning directly with carb cleaner while there out by either soaking or spraying directly will be your best methods.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 07-14-2006, 12:40 PM
88camaroproject's Avatar
88camaroproject 88camaroproject is offline
Send a message via AIM to 88camaroproject
you could buy new injectors for the price of that kit damn. id do that.
87 firebird formula ws6
(currently has a old 78 305 with the following upgrades,
including lots of miles and stock heads and internals....oops)
crane cam cam specs
performance valve springs and retainers, flowtech headers, 255 lph fuel pump,
holley 600cfm carb, weiand single plane manifold, a healty diet.
14.90 1/4 mile....just wait for the 406 to be finished
MY VIDEOS
MY PICTURES
-Tom
Old 07-14-2006, 02:24 PM
Yeah, where? The least I have seen is around $70.00 a piece plus shipping. That ads up to $420.00 plus shipping.
Old 07-14-2006, 04:31 PM
FormulaLT1's Avatar
Fight the powwa!!!
www.summitracing.com pepboys , autozone, www.ebay.com ,advance auto and so on. You can get a set of 6 for under that price.
Old 07-15-2006, 08:30 AM
They must be charging less where you are at. I have checked ebay. They don't have them. Autozone, Advance Auto, Pep Boys are a little over $80.00 apiece. I didn't consider getting this kit without a doing little research including here.
Old 07-15-2006, 08:39 AM
FormulaLT1's Avatar
Fight the powwa!!!
ACC-150617 Accel Fuel Injectors
Fuel Injectors, 17 lbs./ hr., 14.4 Ohms Impedance, 12 V Saturated Circuit Driver, Universal, Set of 6
Monday$199.69
ACC-150621 Accel Fuel Injectors
Fuel Injectors, 21 lbs./ hr., 14.4 Ohms Impedance, 12 V Saturated Circuit Driver, Universal, Set of 6
Monday$199.69
ACC-150619 Accel Fuel Injectors
Fuel Injectors, 19 lbs./ hr., 14.4 Ohms Impedance, 12 V Saturated Circuit Driver, Universal, Set of 6
Monday$199.69
From summit based on your specific car.
Old 07-15-2006, 03:34 PM
Thank you for the Useful and Specific information. This will be a help.
