Go Back   Automotive Forums Car Chat > Pontiac > General Discussion
Old 07-13-2006, 05:10 PM
jrds jrds is offline
Sunfire lowbeam problems
I am having a problem with my passenger side lowbeam lamp.
When the DRL is on, there is nothing on the passenger side.
When I turn lights on, still nothing.
I only have light on that side when I put on the high beams.
I have replaced the bulb and the fuses.
Suggestions?
Old 07-14-2006, 08:20 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Sunfire lowbeam problems
thiers a relay for the lights/DRL's, try checking those .
other than that, you could hav a bad ground.
And Welcome to AF jrds !
1999 Grand Am SS 3.4 OHV
Old 07-14-2006, 08:55 AM
Thanks.
The relay.....where is it located?
And can it affect only one lowbeam?
Old 07-14-2006, 11:06 AM
Whats the year of your Sunfire(I know since it has DRLs its newr But..)?
!! this is important to help identify specific diagrams and locations for your vehicle!!
No it typically affects both, but can just one.
May be in the switch, or the wiring.
kinda odd that only one is effected
I'll check a wiring diagram and see if that gives any clues?
Also check the wires at the lights plugs, and make sure the plug ins are clean and not corroded/rusty.
Ya check the DRL Relay !!
Old 07-14-2006, 01:28 PM
It's a '98
I thought it was weird that it is only affecting one.
I will check the DRL relay but they appear to work fine.
The wiring also seems to be ok.
Old 07-14-2006, 03:22 PM
Well you cant tell a relay is bad by looking at it.
Need a volt/ohm meter.
Try this link Free
Heres a wire diagram
1997-00 Pontiac headlights w/DRL chassis schematic
Hope this helps, if not just hollar!
Old 08-10-2006, 11:06 AM
Still having issues. This is what I have done so far:
1. changed bulb, no luck
2. removed DRL relay, both lowbeams work but are very weak
3. put in brand new relay, back to square 1...no lowbeam on passenger side
Anything else I can try myself before I resort to going to a shop?
Thanks.
Try this link Free
Old 08-15-2006, 01:23 PM
Also If the fuses and wires are all good,
chances are the headlight switch is bad.
