1998 z71 wiper problems
recently my wipers started not working itermittantly, when i turn the switch i hear noise noise coming from the dash area (kind of a rough buzzing soud) but no wiper movement. the water wont come out at this time either. if the truck sits for a while they magically start working again. any ideas.
thanks in advance |
Re: 1998 z71 wiper problems
You can re-solder the connection where the plug connects on the circuit board or buy a new one for about $40. Recall stopped at 97. Same part in our 98's.
WHAT CIRCUIT BOARD? i know the motor is under the hood on the firewall, is that the conection you mean?
If you do not want to fool with fixing your old one.
Go to your dealer and get a new wiper board for the wipers. Some were even under recall have your dealer run your vin no. Open it up and read the instructions or look at the pictures. There is a plastic cover on frontof your wiper motor that has a couple of screws holding it on. Un plug the wiper wirring at motor Remove plastic cover and pull out old pulse board and plug in the new one. Just like un plug and plag and play on a pc. Good luck Mt
I also had this common prob.
I took out circuit board and put some fresh solder on the 2 main connections and fixed. I did some research online and found good pics & instructions - can't remember exactly where.
03 WRX |
I had the same problem, though I could never find the diag of which joints to put the iron to, so I just hit about every joint with the iron and the problem was fixed, most auto parts stores as well as the dealer sell new boards though.
Good luck Tony |
Genius!!! thank you...
