Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 07-13-2006, 04:18 PM
page1 page1 is offline
axle leaking
i was wondering what the seal is called on the front axle where the axle meets the control arm where the shaft comes out of the axle if anyone can help me out that would be great.
Old 07-13-2006, 04:33 PM
myjeepsux420 myjeepsux420 is offline
Send a message via MSN to myjeepsux420
Re: axle leaking
Outter axle seal?
1995 Jeep Wrangler
3 1/2" lift 33x12.50 tires
4.5L stroked I-6
Bored throttle body & Cold Air Intake
Jet Chip Stage 2
Jet Thermostat
Colorado Off Road Rig!!!
Old 07-15-2006, 08:37 PM
Re: axle leaking
yeah i think it is the outer seal i talked to a guy today and he said it could be the inner seal? how would i go about finding that out i have 95 with a 2.5 4cyl any ideas?
Old 07-15-2006, 11:22 PM
Ray H Ray H is offline
Re: axle leaking
There are no "outer" axle seals. On a 95 there is a seal on the drivers side that is located just outboard of the carrier bearing. On the passenger side the seal is located just outboard of the axle disconnect housing. If either of these seals are leaking, grease will drip from the end of the axle tube. The drivers side seal is called an inner axle oil seal, the passenger side is called axle oil seal.
There are plastic dust shields in the ends of the tubes but they arent grease seals, all they do is keep dirt and crud out of the tubes.
Your YJ doesnt have control arms. It has a trackbar or panhard bar that attaches to the drivers side frame rail and passengers side axle tube.
Old 07-16-2006, 12:28 AM
jd-autotech jd-autotech is offline
Re: axle leaking
it maybe coming from your inboard cv boot or out board cv boot clean everything of at start a new fresh look at it.
Old 07-16-2006, 01:08 AM
Re: axle leaking
No CV boots on a Wrangler.
Old 07-17-2006, 12:21 PM
Re: axle leaking
dahr which way did he go george which way did he go
Old 07-17-2006, 02:19 PM
Re: axle leaking
"I will hug him and pet him and sqeeze him....."
