Old 07-13-2006, 03:51 PM
bluebuick91 bluebuick91 is offline
91 3.8 bolt removal help
91 3.8 crankshaft balancer bolt removal do you need a special tool to get the bolt out to remove the balancer , my book just says remove the nut, so i got out from behind the steering wheel, now what.. just kidding, lol but when i try to loosen the nut the whole thing turns how do you hold it to break the nut loose, having to take the timing cover off to get to the cam interupter magnet...thanks, jennifer
Old 07-13-2006, 04:17 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: 91 3.8 bolt removal help
Easiest way, bar none = impact gun.
When not availabe, you need to drop teh flexplate (flywheel) cover in between the motor and trans, as if you were going to remover the starter, that piece of plastic that covers it. then you'll see the flexplate theeth. You'll need to put a large and strong screwdriver or or pry bar (ideal) in the teeth and and against the block to stop it from turning. I'd place my helper ther, bencause if you loose grip of the pry bar, somebody is going to get soe cut knuckles.
Old 07-13-2006, 04:25 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Talking Re: 91 3.8 bolt removal help
Do you have an air compressor and a large impact wrench? You will need at least, an impact capable of 250 ft lbs of torque. If not and you choose to do it manually, you will need a "long breaker bar" and also need to pull the torque converter cover loose, then wedge the flywheel with a large screwdriver or clamp a set of vice grips on the flywheel to hold it, while you loosen the bolt. I would recommend the impact!
