| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
301 upgrade
hey there im redoing a 1977 pontiac bonnevillehttp://img153.imageshack.us/my.php?image=car0088in.jpg
it currently has a301 and im upgrading to a 400 rebuilt for about 1300. i was wondering what was the the stock hp on this thing and what would be the most cost effiecient way to get up around 375-400hp.hopefully without head work if possible.im new to this and appreciate all help ty. |
Re: 301 upgrade
Depends on which 400 you start with. If you're fortunate enough to find a semi-complete late '60s GTO or Firebird 400 engine, you're most of the way there at the start. If you have a mid-70s "smogger", there's a bit more work to be done, but it's quite "doable".
First thing to do, is invest $20 in Jim Hand's "How to Build Max-performance Pontiac V8s" by SA Designs. This is the most complete and CURRENT study of the old Injun (what we affectionately call the "traditioinal" Pontiac). I believe your budget to be a bit on the small side, to really get a good performer that is durable enough to pound on regularly. Avoid "remanufactured" Pontiacs. They've been out of production for so long, little if any true expertise still exists in a rebuilder. A "custom" engine shop with Pontiac experience is the ticket. There are many. Why would you want to avoid head modifications? This is the single most important aspect to power production in ANY engine, not just the Pontiac. The relatively big car can certainly be made to perform. There's a couple of "regulars" at the Pontiac races with '77 and '78s that go 11s in streetable trim. If you spell out your performance requirements and fuel situation, I can make some specific recommendations to get you where you want to be. Most important: Don't allow yourself to be persuaded to use a Chevy engine because "you can't make power with the Pontiac". 'Taint so... (:- Jim |
Re: 301 upgrade
Re: 301 upgrade
IMO, remans are for convenience and for later model vehicles long beyond any "collector" or performance value. The Pontiac V8 went out of production in '78. '79 T/As and Formulas got the last stash they had. Generally speaking, rebuilders concentrate on engines made in the last 10-15 years, as those are the ones that are in demand IN VOLUME. Pontiac V8s have long ago been obsolete for production rebuilders.
Also, remans are built with the cheapest parts known to man, on a production line employing "factory workers", NOT automotive machinists. There's usually one or two real machinists, that roam the floor in a producton shop, putting out "spot fires" when the labor can't figure it out. A reman is certainly NOT a good basis for a performance build. I can't emphasize enough, get the book. It's a piece of cake (figuratively speaking) to get 400 HP and 450 lb. ft. from a 9:1 400 Pontiac. If you're a little more adventurous, 500 isn't out of the question, within certain budget "constraints"... As for the buzzing in your ear about the Chevy, keep quiet, build the Poncho, and THEN, after you've tuned it, and run it at the track a couple of times, tell 'em to put money where mouth is! Jim |
Re: 301 upgrade
Re: 301 upgrade
Good luck to you! That price of $3-4K for a complete 500 HP 455 installed is a bit optimistic. We get $4,500 for just the 500 HP 455, no install included (we don't "do" cars, just engines). Read the book carefully, and be sure all the important points are covered, in particular, the shortblock and the necessary upgrades to make it "live". By no small coincidence, I wrote that chapter (Chapter 2, "Building Your Shortlblock"). I cannot state enough, the rods should be replaced with GOOD ones.
Let me know if I can be of any further assistance. Jim |
Re: 301 upgrade
Re: 301 upgrade
Okay. Sounds about right. One thing, though. The 400 block is significantly stronger than the 455. The reason is simple. 400s have a 3" main journal. 455, 3.25". Since the blocks are essentially the same casting, the "hole" (main tunnel) down the middle of the block is smaller in the 400, leaving more material in the main bulkheads, where it's needed the most. It's common practice today, to "stroke" the 400 to 455 specs. Eagle supplies an excellent kit for this purpose. One must be sure about compression ratio and fuel requirements.
Jim |
Re: 301 upgrade
