Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 07-13-2006, 12:30 PM
ddax's Avatar
ddax ddax is offline
'83 window out of track
The power window on my '83 comes out of the track when putting it up. There is a black triangular clip on the back upper corner of the driver side window that pops out and then the window falls forward back down inside the door.
If I snap that clip back in the window will usually go up but sometimes pops right back out again. Sometimes it binds inside the door and is very difficult to raise.
How do I fix this and how do I remove the interior trim panel to get inside the door to effect repairs?
Thanks,
Dave
Dave
Old 07-13-2006, 12:41 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: '83 window out of track
Thanks,
Dave
The black thing is called a window guide and you can pick these up from a GM Goodwrench service center for like a buck or two apiece. What's happened is yours probably broke or wore out so now it won't stay tracked. Replace this, then shove the window into the track and life should be good.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
