Old 07-13-2006, 11:24 AM
big tex84's Avatar
big tex84 big tex84 is offline
injectors
I found a jdm zc <---what it is advertized as) intake manifold, says it has low impedence injectors, so what harness would I have to get to do the mpfi swap on my 89 dpfi 1.5 std hatch? and will i have to run a resistor box? also what ecu would i have to use
Finally getting my swap done, Thought I would be relieved and satisfied, now I just wanna spend money on other car parts, WHERE DOES THE MADNESS END!!!!
Old 07-13-2006, 03:13 PM
DirtyD777's Avatar
DirtyD777 DirtyD777 is offline
Send a message via MSN to DirtyD777
Re: injectors
you should just modify your std harness and yeah you need a resistor box. If you do a search on here or honda-tech there are literally hundreds of threads for mpfi conversion.
Old 07-13-2006, 04:22 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Re: injectors
You need to do the mpfi swap as stated above, and you should use a SI PM6 ECU with an injector resistor box. Grab these parts off any 88-91 civic/crx SI. You need to rewire your harness at the ecu and at the injectors/resistor, then hook up new intake... done.
PS dont forget to take your old plastic intake and pound it to death with a sledge hammer, piss on it, crap on it, then throw it out...
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 07-13-2006, 06:21 PM
DirtyD777's Avatar
Re: injectors
I like the way you think.
Old 07-13-2006, 07:20 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: injectors
Just for reference:
Peak & Hold aka Low impedance
Saturated aka High impedance
You will always run an injector resistor box with Peak & Hold/Low impedance type injectors. Nothing else matters. It doesn't matter what year the car is, what obd the engine is, what obd the ecu is.
Technically, you don't even need the box. All that's in there is four 6 ohm resistors. You can pick them up at an electronics store and solder them inline to save a few bucks.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 07-13-2006, 11:03 PM
thefooshmeister thefooshmeister is offline
Send a message via AIM to thefooshmeister
Re: injectors
ive got an pm6 ecu if you cant find one near you. just pm me. why does he have to rewire his injectors? is the zc obd-1?
98 Jetta GLX VR6-vroom vroom!!
91 CRX Si-R..busted..
Old 07-14-2006, 02:21 AM
Re: injectors
Oh and just to add to the shopping list... you need to get an HF/SI distributor and replace it with your STD one. So an ecu, resistor box, and dizzy can be pretty damn expensive..try not to pay over 100 for all these parts. If you do spend over 100 you could damn well pick up a single cam ZC for like 350 instead... So IMO dont put too much money into making your D15B1 fast...cause a D15 wasnt never meant to go fast...and will NEVER go fast.
Old 07-14-2006, 11:02 AM
big tex84's Avatar
Re: injectors
i agree, im just tryin to do a little for right now, the dpfi suxx ass and yes i look forward to destroyin it, if you want you can set it on fire after im done so that someone else can have some fun too.
