Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 07-13-2006, 12:08 AM
metalhedskater's Avatar
metalhedskater metalhedskater is offline
Send a message via AIM to metalhedskater
Radiator help...FMIC causing overeating
Okay so last summer i installed a FMIC and noticed the car overheats about 80% up the meter when im on the highway...But if i turn the heat on the car it runs about 55% up the meter....I know about the fan mod and everything and plan on doing it, but i still wanna get a nice aluminum radiator to make sure i dont get anymore overheating....id hate to spend 300-400 on a fluidyne so i was looking at this one
http://cgi.ebay.com/ebaymotors/95-96...07123637QQrdZ1
How good do you guys think this radiator is? You think it will end up leaking on me or some bullshit like that? What are the measures taking when buying a good radiator? I know i havent been on in forever, but think for the help guys!
99 GST/evo 3 16g/3" Catback/Intake w/filter/UICP/1g BOV/Complete prothane motor mount inserts/Boost gauge/AF ratio gauge/MBC/NGK Plugs/HotWires/17" Sport edition fox 5 racing rims w/Fuzion tires
One retarded ass site! Geeeeeeeee
My Car
[url=http://www.myspace.com/nobledsm[/URL]
Old 07-13-2006, 12:23 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Radiator help...FMIC causing overeating
I dont know man, I would go fluidyne. Or get a couple bigger, much higher volume fans instead. Just remember to duct them good.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 07-13-2006, 12:22 PM
kjewer1 kjewer1 is offline
AF - Advisor
I don't think it matter much which radiator you have if a front mount is blocking airflow to it The trick is to get airflow to the radiator. Jumper the relays so both fans come on at least, that should help. Then start looking for places to add some shrouding so the air can't just spill around the radiator instead of going through it.
On my 2g a 24x10x3.5 FMIC worked fine, but when I went to a core that was 24x12x3.5 it blocked enough air to the radiator to cause the problem you describe. For me installing the second fan and having them come on simultaneously was enough, but some people have to add shrouding as well. Maybe you'll get lucky.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-13-2006, 02:34 PM
TheRomer TheRomer is offline
Same here. I have the same core kevin did, and I overheated at first. I then added that second fan, now i do not overheat.
Chris Winchell
95 GSX 12.5 ET with a 1.9 60' at 115 mph
Actually have traction this year
90 TSI <Project Acer>
2.0L, 2400 lbs AWD, t-67 goodness
Old 07-13-2006, 03:12 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
I believe if you have a cooling system that is working 100% fine, you'll be fine. I have a 24x12x3.5 and have never overheated once. I can sit in traffic all day with the a/c on, drive on the highway as much as I want. Before you spend hundreds on a radiator, I would make sure the problem isn't elsewhere. I'm also dealing with upper 90's to 100's everyday now in the summer, no overheating. My point is make sure it's not something else first, try changing out the thermo, drain and refill the coolant, add water wetter, etc. You never know, it might be something like this. If those don't work, you're likely going to have to deal with directing airflow to the radiator. You can have the nicest aluminum radiator there is, but if it's not getting airflow, it will ovehrheat.
now - 2000 civic
soon - 2002 is300
Old 07-13-2006, 03:26 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
I agree. For now I am just sticking with my stock radiator since theres absolutly nothing wrong with it. I may add a lower piece to direct air up to it just because of my fmic being so huge. (Firebirds are designed with a piece to direct air up into the radiator. I think I shall steal the design for my DSM. lol)
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 07-13-2006, 10:11 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Do you still have the a/c condenser in? Cause if so that's a pretty big block right in front of the radiator. I have a 28x10x3.5 fmic and have never had problems and i'm on 1 slim fan.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 07-13-2006, 11:37 PM
So you guys obviosuly think that the radiator will do jack shit, right? Not even help a little? Im gonna try the fan mod as soon as possible, but isnt it as same as having the heater on??
Also i have no idea how im gonna direct air to that radiator...anyone have any ideas or illustrations that you may have come across?
Thanks everyone!
P.S. I see that you have moved up in rank since ive been gone Kevin.....its about time....you deserve it
My Car
Old 07-13-2006, 11:38 PM
Oh and yes i still do have the a/c condesner in...i mean i dont wanna lose my a/c...... not that i even use it becuase the overheating...
My Car
Old 07-14-2006, 12:49 AM
AF - Advisor
Thanks everyone!
Thanks!
It certainly wouldn't be a bad thing, but it could be a waste of money if other simple solutions would solve the problem. The fan trick worked for me, I would seriously try that first. It's cheap/free. If that doesn't work try the shrouding. I Don't have any pics, but take a look at the IC and the radiator. You want to seal them together, as well as the bumper cover if possible, so air is forced to go through the IC, then through the radiator. The factory always uses shrouding like this, but we end up removing it to install the IC. The EVO has an AWESOME setup. The top two openings in the bumper are above the FMIC and go straight to the radiator. Even with the same 24x12x3.5 core, I run all day at 180 degrees, even with the AC on, etc. I wonder if you can simulate this on a DSM without it looking half assed and retarded.
Kevin Jewer
Old 07-14-2006, 01:06 AM
Originally Posted by kjewer1
Thanks!
What exactly do you mean "seal" them together? Like get a zip tie and tie them together maybe? Also where can i get some shrouding.....Home depot? And just to be clear when you say shrouding you mean sort of like a duct setup, right?
Thanks again!
My Car
Old 07-14-2006, 01:10 AM
AF - Advisor
Yes, most people use thin sheet aluminum because it is light and easy to bend. Basically just box in the gaps between the bumper, IC, and radiator, so air can't go AROUND the radiator. Air takes the path of least resistance, after all.
Kevin Jewer
Old 07-19-2006, 12:38 PM
Ok cool im gonna try the fan mode and if that doesnt work ill try the other suggestions....Thanks for everyones help....Ill keep you guys updated
My Car
Old 07-28-2006, 03:09 PM
Okay guys so i did the fan mod and changed my radiaor cap and the car doesnt over heat anymore. However, when i have the A/C on it seems as if the two fans running has no effect at all. So what does that mean? Something else is wrong?
Also, is there another way of doing the "fan mod"? I have a switch that manually turns on both fans...i thought i once saw a thread/site where it showed that both fans automatically turn on once one fan turns on (hence no bypass switch)....
My Car
Old 07-29-2006, 05:27 AM
AF - Advisor
It should be in the vfaq. It involves tying the secondary fan to the main fan at the relay box. That takes care of any over current concerns That is the mod I was refering to. The ECU will still turn the fans on at 210, but with 2 they will actually do something.
The AC creates a lot of heat! Even with both fans on it is unlikely that you can run the AC with a big FMIC and not overheat without doing some more work. Shrouding as I mentioned earlier, an extraction vent in the hood is a good idea (EVO came with one, for reference). An externail oil cooler can take some more load off the cooling system. Etc. You can also reduce the amount of coolant in your mix, but if you are having other problems this is just more likely to make the boilovers worse when it gets to that point. Coolant sucks at transfering heat, water is better, so some poeple switch to a 80/20 or 90/10 mix, with some water wetter. I would try this last though, unless you think you are running a relatively high concentration of coolant, like 50% for example. Sounds like you don't actually over heat any more, so reducing your coolant concentration should be ok. Just remember to put it back up for the fall.
Kevin Jewer
