Old 07-12-2006, 11:21 PM
jtstuedle jtstuedle is offline
1995 Camaro Idle
My idle jumps from around 600-1200 RPM, when sitting in park at a damn train, it idles around 900-1100, in drive with brake engaged around it is always different, sometimes 600, sometimes 1000 etc. Did a minor tune-up about 3-4k miles ago, new plugs/wires, rotation of tires, didn't check the timing(its likely the problem, but I don't have a timing light). Other than the timing, what else could make my idle fluctuate so much?
Old 07-12-2006, 11:28 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
Re: 1995 Camaro Idle
might be the tps sencer also.
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 07-12-2006, 11:36 PM
666_speed's Avatar
666_speed 666_speed is offline
Son of Satan
Does it trip the SES light that you can have scanned at the parts store?
Old 07-12-2006, 11:39 PM
97cavalier's Avatar
ya because the 95's have OBD2 in them
Trips no lights, gonna get a timing light soon though...if it's not the timing, I'll move to the tps as cavalier said...vaccum leak is possible, but would it still vary in its idle if there happened to be one?
Old 07-13-2006, 09:17 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
OBD I hybrid
Old 07-13-2006, 12:11 PM
97cavalier's Avatar
pretty much same thing.
Old 07-13-2006, 12:50 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Oh no he didn't . Nope. Completely different. The hybrid is closer to OBD1 than OBD2. It uses most of the same sensor and commands as a OBD1 system but has a soldered non removable reprogramable eprom and doesn't not trigger the codes with the check engine via jumping the terminals, instead you have to scan. To me and many f-body users the hybrid is the most saught after cause of the ease of programming,
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 07-13-2006, 02:11 PM
CamaroRS92 CamaroRS92 is offline
Vacuum leaks , even very small ones can cause irratic idle speeds
That is where i would check first, - since you did a tune up you may have moved a dry rotted or cracked hose and created a vacuum leak
