Go Back   Automotive Forums Car Chat > Mitsubishi > Mirage
Old 07-12-2006, 09:01 PM
brokedownmirage brokedownmirage is offline
Should I fix or junk my car
I have a 1997 Mirage LS Coupe w/ 128,000 miles on it. It was in decent shaoe overall, minus a non-functioning air conditioner. The probelm is the automatic transmission recently blew on it and the cost to rebuild it is 1600. Is it worth putting this kind of money into this car? Any help would be appreciated.
Old 07-12-2006, 09:20 PM
G-man422's Avatar
G-man422 G-man422 is offline
Re: Should I fix or junk my car
Cant you buy a used tranny somewhere 4 cheaper?
Old 07-12-2006, 10:00 PM
Not here. It is a tricky situation. I just moved to maryland from PA. I don't have any auto contacts down here that I would trust enough for that. The car is at a shop that was recommended by AAA and people in the area. They said thats the only option that rebuilding it was my only real option. If i were still in PA, I knew people who worked in garages who I would trust to get me a used tranny. Without that connection, I could just be buying one that will blow in another 2000 miles.
Old 07-13-2006, 03:03 PM
DFBonnett DFBonnett is offline
Is the trans really blown and needs a full rebuild ? Get a second opinion. After you are really in command of all the details you have to look at the numbers and make a decision.
Old 03-10-2009, 12:48 AM
Acebankai Acebankai is offline
well if you can rebuild your own tranny its alot cheaper and you can trust yourself. rebuilding your own tranny is easy as anything. ive done like 8. its basically one whold unit that you take out. you probably messed up the sprocket or one of the planetary gears. take it apart and check
Old 03-10-2009, 01:25 AM
jbracefan1977 jbracefan1977 is offline
Banned
I agree.........
Old 03-10-2009, 01:58 AM
plus thats a little high to be charging for a tranny job. if you don't want to overhaul yourself get somebody elses opinons.. its still going to be easier to do it yourself. if you need any help message me and i'll walk you through it.
