89 Buick 3.3L engine won't start
Hello.
My 89 Buick is having some starting problems. I just put in a new fuel pump, plugs,wires,starter. It will crank then backfires through the intake. It will also crank normal for a few seconds then slow down for a second then crank normally again. When it slows down, thays when it backfires through the intake. I would really like my car to run again. Please help. |
Re: 89 Buick 3.3L engine won't start
before and after I fixed the fuel pump.
Make sure you have good compression, then disconect the maf, if so equipped, then try it and post back results.
It has good compression. I also had problems with the maf. It used to be disconnected and still had the same problem. I use to use starter fluid to start the engine.
Start from scratch, check fuel pressure, get a noid lite, make sure all the injectors pulse, scan it and check for cranking rpms, will it start and run now with carb cleaner in the intake?
I know all the injectors work and it has fuel pressure. It is also cranking normally. It still does it. It won't start. It just backfires through the intake. If I open the intake, a big flame spits out.
