Go Back   Automotive Forums Car Chat > Toyota > Supra > Maintenance
Maintenance Have questions? Find answers. Help out fellow Supra owners.
Old 07-12-2006, 06:09 PM
columbomd columbomd is offline
Question pulling fuel injectors
what do i need to do to pull the injectors from a 1986.5 supra 3.0 sport hatchback/
Old 07-12-2006, 06:13 PM
TcmaBoy's Avatar
TcmaBoy TcmaBoy is offline
AF - Advisor
Re: pulling fuel injectors
Remove the fuel rail and pull them out. Be careful when disconnecting the electrical connectors. The old plastic may be brittle and the connectors may break off. Be sure to replace the o-rings before reinstalling the injectors. It helps to use a little petroleum jelly on the o-rings for installation. It will help prevent the o-rings from pinching during installation.
Don't you SAS me boy.
Please wheel responsibly.
http://www.treadlightly.org/
Old 07-12-2006, 07:53 PM
do i need to make sure there is no fuel pressure or drain the fuel tank or anything like that?
thanks
columbomd
Old 07-12-2006, 08:09 PM
TcmaBoy's Avatar
AF - Advisor
You can eliminate the fuel pressure by pulling the fuel pump relay and cranking the motor.
