Go Back   Automotive Forums Car Chat > Ford > Super Duty
Old 07-12-2006, 05:19 PM
Millermagic Millermagic is offline
2001 5.4 Changing Fuel Filter
Our 2001 5.4 has been sputtering lately at part throttle cruise and accellerating.
At first, it doesn't do it, but as the truck runs longer, it gets worse. Turning it off for a few minutes helps - either clogged fuel filter or water in gas right?
How would I change the fuel filter.
- Leather - Transmission Cooler - Gen III Tweeter Sails - Gen III Rocker Covers -
As you walk through the valley of RICE, you shall fear NO V-TEC, for torque is with thee!
Old 07-26-2006, 11:10 PM
yotermanic yotermanic is offline
Re: 2001 5.4 Changing Fuel Filter
Do you have a check engine light on? It sounds more like an ignition miss, than a fuel problem to me. Anyhow, if you want to try a fuel filter first, you need the little spring release tools, you can get the full set at any o'reillys for twelve bucks. Then you crawl under the driver's side and push the release tools into the collars on the lines (you'll know what I'm talking about when you see them) and pull the lines off, then snap the filter out of it's spring bracket and snap the new one in and shove the lines back on until they click. I always give the lines a quick tug afterwards so I know they aren't going to blow off under pressure, not a hard tug, just a quick one....also, IT"S ABOUT TIME WE GOT A SUPER DUTY FORUM!!!
Old 08-01-2006, 05:40 PM
Turns out Coil#7 was bad and when the engine got hot, it started working less until it didn't work at all.
But I definitely have to use the special tool to get the old filter off? I still want to change it becuase of what was found on the cap.
Old 08-05-2006, 09:25 PM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
Yes, you will need the special tool to change the filter.
Old 04-11-2008, 04:46 PM
semisendiz semisendiz is offline
Here , Here, I Have Just Gotten My First F-250; And Yes, Good Thing About The Forum !!!
