Old 07-12-2006, 03:39 PM
Jcrane88 Jcrane88 is offline
Send a message via AIM to Jcrane88
not a camaro or a chevy..but...
its A FORD im sorry....but i tried the guys over at the ford forums and i couldnt get help ......i know you guys arent ford experts..but i dont know what else to try...Please dont execute me
the vehicle is the 86 bronco in my sig trans is a A4LD auto trans
it doesnt move in any gear the engines just revs freely of it....when you shift it into a gear i think the engine lowers in rpm a bit like it normally would..but it just doesnt go no where.....my brother says that it just done it all of a sudden ( but if he did something wrong he wouldnt admit it )...........
I bought it from my bro for $35 its just gonna be my run around the woods mudding beater any ideas or where to look would be helpful
1984 Camaro 5.7L 350
700R4
Holley 650 Cfm
Edelbrock Performer Intake-Manifold
Crane Cams Duration @ .050": 204/214 Lift:420/442
Summit HEI Distributor
Hedman Shorty Headers
Hedman Y-pipe
Dynomax Turbo cat-back
NOS Decal
VTEC Decal
Old 07-12-2006, 03:41 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: not a camaro or a chevy..but...
Fluid?
Old 07-12-2006, 04:04 PM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
sounds like your auto tranny is fried.. check fluids, if its all black you prolly have burnt bands, gotta get it overhauled...?
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 07-12-2006, 04:48 PM
if i can verify the trans is bad im just gonna part it out......as far as the fluid goes, my brother tried out his mechanic skills (AHHH) on it..he took the tranny pan off to inspect and put it back together without a gasket and lost all the new fluid...he started the engine several times after that wihtout fluid...so it certainly didnt get better..............i dont have any idea what color the fluid was
700R4
Holley 650 Cfm
Hedman Y-pipe
NOS Decal
VTEC Decal
Old 07-12-2006, 05:14 PM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Well have you or him tried dropping the pan again and properly reinstalling it? Also, if the pan has a magnet attached to it, as most do, check it for metal shavings. If you see some shavings on it, then odds are 1 or more bands have snapped in it. Also make sure to change the tranny filter as well, not just the fluid.
Same exact thing happened to my friends Malibu recently. I dropped the pan replaced the filter and gasket. Poured in some new fluid and it worked like a charm. There were some metal shavings in the pan though, so I told my friend not to expect much more life out of that tranny without getting it checked out at shop so they can rip it apart and find out whats broken.
So try that and see if it helps.
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 07-13-2006, 08:51 AM
wrightz28's Avatar
Well, some "furriness" as I like to call it on the magnet is normal, it's wear from the clutch packs. The place you REALLY don't want to see shavings is in a diff.
Old 07-13-2006, 02:07 PM
blindeyed's Avatar
eBay aDdict™
Ah well guess it's not as bad as I had saw it too be then. The particles were as you described, "furry" with a very tiny chunk or two here and there. Glad to have a guy like you around who knows a thing or two about transmissions, as I'm not very keen on them. I wish I could get to work on some and learn some things about them, but with just starting college and working practically every day I just don't have the time.
- Jason
Old 07-13-2006, 03:16 PM
wrightz28's Avatar
Yeah,I just thought I'd throw that out there as a general statement. There's very few pans you'll drop and not find anything on the magnet, I know if I didn't anything, then I'd be worried .
In contrast, that's also why it is said that if the trans has high miles (100K miles or more) and it's never been serviced, if the fluid is gritty, it is more than likely best to leave it alone. The grit is the friction disk materials that used to be in the clutch packs and wore off and is now floating around in the fluid. Once that fluid is drained, there goes your material, albeit in the wrong place but there. And thus you only have the metal disks + fluid = no go.
Old 07-13-2006, 07:20 PM
ive changed plenty of filters before............In my 84 camaro it had alot of small metal shavings ( furry as you call it) stuck on the magnet..no gears or what-not lol....i'll try that and see what i get.. im gonna change the filter and fluid, start it up and pay attention more..seeing its mine now.....
its not solved yet but you guys have helped out alot more than the ford guys did Thanks
John
700R4
Holley 650 Cfm
Hedman Y-pipe
NOS Decal
VTEC Decal
Old 07-15-2006, 11:55 AM
stoned_pimp420 stoned_pimp420 is offline
Send a message via Yahoo to stoned_pimp420
it sounds like what my dads ford windstar done before we cancelled insurance and burned it, except we had just had the fluid changed and drove it for about 3 weeks and the he was sitting at a red light and when the light turned green he let off the brake and stepped onto the gas, it lurched forward and acted like it caught neutral, it wouldn't move in drive or reverse, he agreed to not putting anymore money into the pile of crap so he done what any warm blooded creature would have done, he let me and all of my friends totally destroy it, beat the fuck out of it, blew the already halfway gone motor, played tug o war with a tree and a truck using it as the chain and finally burned it and to the scrapyard it went. not like any of the rest helped you out but I was just saying.
I'm back after a long mental evaluation and heavy medication!
If you can't be a good example, you can always be a horrible warning!
