Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 07-12-2006, 01:01 PM
toicy4ya's Avatar
toicy4ya toicy4ya is offline
How to install a Rear Strut Bar?
Sup guys,
I currently own a 99 eclipse spyder and am considering installing front and rear strut bars. My question is the following;
1. How difficult is it to install a rear strut bar?
2. Is it something I can do myself?
3. Is it worth installing? (are there any notable differences?)
4. Is there a write up or site that offers instructions on how to do this for our cars?
Thanks
99 Eclipse Spyder GS
Old 07-12-2006, 04:12 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: How to install a Rear Strut Bar?
If you look at the strut bar, and look at where it goes, you'll think back to this thread and probably laugh It really is that simple.
As far as it being worth, rear bars are always helpful in DSMs, fronts less so. In a convertible though, both are probably very worthwhile.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-12-2006, 05:28 PM
showstopperz's Avatar
showstopperz showstopperz is offline
I may be wrong but you might not need a rear bar seeing that you have a spyder. If you look behind your carpet covered cardboard in the trunk you will see that a crossmember support brace is already there. It looks like a big X and it is tubular metal. So to me it seems like it would be pointless to install a strut bar in the rear unless you wanted it for looks? But then again with a strut bar in the rear would the top go down into the spot where it sits correctly?
Like I said I may be wrong I never tried this with my spider because as I see it, it would be pointless.
1998 spyder gst 5 speed
2007 Mazda SPEED3
Old 07-12-2006, 05:43 PM
AF - Advisor
Those are good points. I've never seen what the back of the spyder looks like either.
Kevin Jewer
Old 07-12-2006, 11:25 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
You can't put a rear strut tower bar in a Spyder. Trust me, I know. But you can in the front.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 07-13-2006, 07:50 AM
toicy4ya's Avatar
Actually you guys are right... It does have a rear cross bar just behind the rear seat.
What about the front strut tower bar, do those really make a noticible difference in car handling?
Old 07-13-2006, 08:30 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Front strut bars don't seem to help that much, but it wouldn't hurt to put one on anyways. Why are you trying to add all of these handling upgrades? Do you not like the way your car handles now?
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 07-13-2006, 09:01 AM
Ha I finally made a point +1 for me !!!
2007 Mazda SPEED3
Old 07-13-2006, 11:15 AM
ned032002's Avatar
ned032002 ned032002 is offline
I like the way that a strut bar looks so to me weather it improves the handling or not I just like the way it looks.
Old 07-13-2006, 07:05 PM
Well, here is another point for you: In Spyders it doesnt matter if the car does or doesn't really need a rear strut brace, because you can't put one on it anyway.
Caleb
vanilla gorilla
Old 07-13-2006, 10:13 PM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
The differance made with a front strut tower bar is not that noticeable. I dont know about the spyders but I think the normal GS and the RS models dont even have a rear sway bar. So that is something that I would look into....Sway bars are much better for handling than strut tower bars....not sure if that is what you are going for but hope it helps.
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 07-14-2006, 12:23 AM
Holset powered 420a
The GS did come with a rear sway bar, the RS didn't. Even if you already have a sway bar changing it out for a bigger one is going to improve performance. I am going to change mine soon because my car understeers some.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 07-14-2006, 08:40 PM
Spyder GS's did not come with a factory rear sway bar. To install one you have to also buy the factory mounting hardware.
Caleb
vanilla gorilla
