| Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
I am now on my 3rd battery since I bought this car last year. I put a new battery in it a few months ago and it has ran fine. Last week the car sat for 8 days straight, and last nite it didn't have enough juice to even operate the door locks. This is the second time this has happened now. If I run the car on a regular basis, everyday or every other day, it is fine. If I jump it, it runs fine, so that tells me the alternator is okay. The only time I seem to have a problem is when the car sits for a week without driving it. I have no add-ons or accessories wired into the car, even the stereo system is stock. Really stumped with this. Please help!
Thanks... Last edited by musclhed; 07-12-2006 at 02:06 PM. |
Re: Help! 99 GT keeps killing batteries...???
You have a constant drain somewhere.
1969 Cougar 357w & TKO - 475hp |
Its a pain to troubleshoot.
If you know its going to be sitting for a while, I would pull some fuses and start narrowing down where the drain is.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper. |
I would check the basic stuff first: glove box / trunk light mach audio amp remote switch mach audio radio accessory ignition switch alarm system I bought a beemer today. |
[quote=brokenantimatter]That's not really needed, they make insturments for DC power that would let you trace power consumption and levels.
I would check the basic stuff first: glove box / trunk light mach audio amp remote switch mach audio radio accessory ignition switch alarm system --------------------------------------------------------------------- Yeah, I know there is a constant drain somewhere, I was just hoping that someone may have had this problem before to help pin-point it. Where would I take it to have the drain sourced out? Or is this a tool that I can buy? and where/how do you use it? Plug into the diagnostics/computer plug when the car is off so it can sense what is on? I know the tration control switch is bad, as I can't turn off the trac control. Could a bad switch do this? Autozone has been pretty cool about taking the batteries back each time. I just take them to different store locations... Any other insight would be greatly appreciated...... Thanks! |
Re: HELP!!! 99 GT keeps killing batteries...???
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex -1999 Ford F150 |
I am having the same exact problem with my 01 gt I am on my 3rd optima red top and my alternator is good I heard a rumor it might be the factory stereo system draining the batteries you might want to start there. let me know cuase I am lost.
A few months ago my alternator was squealing so I replaced it. Since I replaced it there have been NO problems with losing power. Before if the car sat longer than 4 or 5 days I wouldn't even have enuf power to use the door locks. Seems that the alternator was the issue... |
