Old 07-12-2006, 11:42 AM
phil-l phil-l is offline
Have you seen a harmonic balancer fail like this?
I discovered a failed harmonic balancer on a friend's '96 Mustang 3.8 V6 auto (no performance mods; bone stock) that seems to be pretty unusual.
Take a look at the pictures here:
http://community.webshots.com/album/552022226RktMDS
Yes, the balancer is broken into two pieces. And look at that keyway: It's more than *twice* as wide as it should be.
I suspect that the balancer cracked some time ago - but was held in place by the crankshaft bolt. As long as everything stayed in place, it still worked OK. But the vibration started abrading the keyway and causing movement along the crack line. The '96 gets its ignition timing from the crank sensor and the star gear on the balancer, so timing quick got out of whack.
Questions:
- Any idea what really caused a failure like this? Has anyone seen a similar failure?
- I plan to simply replace the balancer, put it all back together and hope for the best. Are there issues I should be aware of, or other problems I may have missed?
Thanks for any insights.
(Apology to admin/moderator: I also posted this is the "Problem Diagnosis" forum - before realizing how little traffic it gets)
2000 Windstar LX 3.8
1995 Contour GL 2.5
1986 Mustang GT 5.0 --> Sold, but missed on sunny days
Old 07-12-2006, 01:16 PM
brokenantimatter brokenantimatter is offline
Re: Have you seen a harmonic balancer fail like this?
hmmmm?
Ford has a really bad reputation for building shotty crank and cam related parts and I have seen a similar problem happen 98 Windstar where a bad ignition caused the harmonic balancer to viberate to the point where it the teeth sloshed off and and cracked 2/3rds through. They both use the same engine so I pretty sure the powered metal balancer is found in both....Ford has a really bad habbit of cutting corners.
Old 07-13-2006, 12:35 AM
silverstangs's Avatar
silverstangs silverstangs is offline
Send a message via AIM to silverstangs
I have seen that before, normally caused by a belt that was too tight. Caused by a belt being too small.
My ride at my site Silverstangs.
Old 07-13-2006, 01:01 AM
AltecZX2 AltecZX2 is offline
Send a message via MSN to AltecZX2
hell ive seen fords that have a harmonic balancer, and internaly balanced and still get crank walk lol
FORMERLY: zx2srdotnet(1,380 posts)
2001 Esxort ZX2 - Traded
2000 Escort ZX2 S/R - Sold
2003 Mustang Mach1 - Totaled
2014 Altima 2.5 S - Purchasing Soon
Old 07-13-2006, 09:37 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Wow, I would contact your local Ford dealer and see what they say. Look at the second picture of the balancer, you can see the center ring has walked a little bit and is not uniform. I had the same problem a few years ago on my balancer, but I caught it early on, replaced it and no problems. Good luck, keep us updated.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
