Old 07-12-2006, 08:55 AM
Pac-Man_G Pac-Man_G is offline
Send a message via AIM to Pac-Man_G
Need Help Fast!!!
is it possible for a different distributor then what should be on a motor will lower the rpm peak? for example, b18a LS distributor on a b18c5 type R motor? or a d15 non vtec distributor on a d16z6 vtec motor? the reason why i'm asking is because i have a d16z6 swapped into a EG cx but it only revs to 6,000 RPM where is should be reving to at least 7,500 RPM.... a buddy told me that they could have used a different distibutor then the one on the d16z6 any ideas why its not reving that high?
Old 07-12-2006, 11:04 PM
fiberglasscivic's Avatar
fiberglasscivic fiberglasscivic is offline
Send a message via AIM to fiberglasscivic Send a message via Yahoo to fiberglasscivic
Re: Need Help Fast!!!
Your timing could be off or you could have a problem with your ecu. Is your check engine light on?
AF COMMUNITY GUIDELINES
Old 07-13-2006, 07:55 PM
nope, no light at all comes on...the ECU is a P28 and it looks like everything is hooked up right... my timing maybe off but i dunno. could it be for far advanced for it to not rev that high?
Old 07-14-2006, 01:40 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
You've made like 6 threads asking the same thing and you haven't checked your timing yet? Check your timing man, and please don't make multiple threads about the same question.
