Go Back   Automotive Forums Car Chat > Honda > How-To's and Walk-Through's
How-To's and Walk-Through's Here's where we show you how it's done!
Old 07-12-2006, 08:54 AM
Pac-Man_G Pac-Man_G is offline
Send a message via AIM to Pac-Man_G
i need some vtec help!!!
is it possible for a different distributor then what should be on a motor will lower the rpm peak? for example, b18a LS distributor on a b18c5 type R motor? or a d15 non vtec distributor on a d16z6 vtec motor? the reason why i'm asking is because i have a d16z6 swapped into a EG cx but it only revs to 6,000 RPM where is should be reving to at least 7,500 RPM.... a buddy told me that they could have used a different distibutor then the one on the d16z6 any ideas why its not reving that high?
Old 09-22-2006, 07:17 PM
JDMcivicEG JDMcivicEG is offline
Re: i need some vtec help!!!
you have to use a vtec distributor on a vtec motor, and you also need to run it on a vtec ecu.
