Go Back   Automotive Forums Car Chat > Buick > Century
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 07-12-2006, 09:17 AM
drjeckles's Avatar
drjeckles drjeckles is offline
Cool Possible Wiring Problems?
I just bought this car and recently changed the spark plugs and spark plug wires and my check engine soon light comes on and the engine runs rough. My car is a 1994 Buick Century 3.1 liter V-6 engine. It ran perfectly before I changed the plug and wires, sigh.
My brother has a spark tester/analyzer and that checks out OK. I got Pep Boys to do a scan for $20 so did not have to buy a tool or pay GM $85 for it.
The error codes are:
P0321 24X Reference Circuit
P0342 Cam signal Circuit (loss of cam pulses)
P1640 QDM "A" Circuit
P1650 QDM "B" Circuit
P0740 TCC Circuit
I had to remove the Coil pack and some vacuum hoses along with a few connections to the coild pack to get to the plugs and wires.
Many of the vacuum hoses are/were questionable and I have been repairing replacing many. The wiring in areas looks like there have been problems before and there is actually a new wire outside the harness to make the AC switch on.
So far I have been unable to find any poor connections, loose wires, or vaccum connections, but I suspect that the problem is wiring related. I am very open to suggestions/advice/similar experiences.
1. Would a wiring harness connector with bad connections (corroded or broken where I cannot see them) explain these problems?
2. Would you suggest buying a new universal harness, a new OEM harness, Used harness from salvage, running idustrial grade shielded wiring to the critical sensors and bypassing the possibly bad sections, or something else?
My budget is only a few hundred so I don't think the GM shop could help that cheaply. This probably rules out a completely new OEM wiring harness too.
PS
I have access to AllData diagrams and troubleshooting for this vehicle.
Old 07-17-2006, 08:58 AM
drjeckles's Avatar
Re: Possible Wiring Problems?
Found problem!
There is difficult to find group of inline fuses that can only be accessed by removing the glove compartment and fuse block. Even with diagrams and a photo from the shop manual (which showed the old style round fuses instead of the bayonet type that were in the car), I went back and forth the diagrams and car 3 times before finally locating the blown 10 A fuse. It turns out that that fuse supplies power to the crank sensor and will cause all these errors. When I reset the computer, all the error codes disappeared.
Alas, I also had one bad AC/Delco sparkplug, which I found much to my disappointment when the car still ran rough.
I then cleaned up the mess left by the last shop that tried to troubleshoot the problem before I bought the car and all is well (with the wiring anyway, grin).
Old 03-30-2008, 12:45 AM
wilkie_5 wilkie_5 is offline
well, hopefully your problem is also my own. i have the same car with the same situation... wish me luck.
Old 03-30-2008, 06:32 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Good luck.
Sorry but please check the date and do not resurrect old threads. Thread closed. Following the guidelines below you may start another on your issue for further discussion.
Click here
Timeslip 08/12/06
AF Community Guidelines
Closed Thread
