Old 07-12-2006, 12:45 AM
1991HB 1991HB is offline
Send a message via AIM to 1991HB
bad ground?
i have an '88 hatchback. Whenever I turn the blinker on the heat hand jumps up and down. Whenever I turn the headlights on(high beams only) the heat hand and the fuel hand go all the way up? Same thing when I turn the hazards on. I asked an electricain and he said it's a bad ground somewhere but they want $65/hour just to find it. Anyone have any good ideas where it could be at. THanks
Old 07-12-2006, 03:48 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: bad ground?
check your valve cover, and thermostat grounds. Sand all contact points down to bare metal and then tighten them back on.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 07-12-2006, 10:39 PM
CZ-R's Avatar
CZ-R CZ-R is offline
Send a message via AIM to CZ-R
Re: bad ground?
^^^ what he said... but I'd be looking for 'short's' as well. Take your cluster cover off, get a volt meter & go nuts It shouldn't be too hard to find...
Old 08-08-2006, 04:08 AM
Re: bad ground?
instead of starting a new thread I thought I would keep this one going. If you have read the previous posts than you know what my problem is. I did what you guys said and it is still doing the same thing. I talked to a couple of electrians and they said that it could be in the blinker switch itself. So I went out and bought another blinker switch...used of course...a new one would probably cost to much. Still it didn't fix anything. Any of you have anymore ideas. The person I bought this car from left wires for a tach and an amplifier in the car and they were still hooked up just no amp and no tach. Could they of shorted something out since they were hot wires just lying in the car??
Old 08-08-2006, 05:00 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Re: bad ground?
Maybe the wires behind your cluster controlling fuel and temp have melted and come into contact with the blinker wire, so whenever you turn on your blinkers, the fuel and temp guages recieve that signal. I'd say follow the wires behind your dash and inspect them to see if there worn out or coming into contact with each other.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
