Old 07-11-2006, 11:34 PM
Cait Sith Cat Cait Sith Cat is offline
Send a message via AIM to Cait Sith Cat
Curious: Swap I6 for a V8?
I have a 1996 straight 6 F150, and I was wondering what would be involved in swapping the engine for a 302 (or even a 351?) Could I just drop a new engine in? Are the mounts the same? The cooling system?
1994 F-150 XLT 4x4 ext. cab 5.0
R.I.P. '96 300, may those dirty mechanics burn in hell.
Old 07-15-2006, 05:50 PM
BMWJosh BMWJosh is offline
Re: Curious: Swap I6 for a V8?
well i'd hate to be the bearer of bad news but i doubt the mounts are the same,hoses for the radiator prolly different,but the big prob. being its 96' the wiring harness is totally diif unless u have the V-8 wiring harness and comp. I wouldn't even bother.
Old 07-28-2006, 08:35 PM
dhaywood77 dhaywood77 is offline
In my humble opinion the straight 6 is a great engine, every bit as good as the 302. If your gonna go for the swap go straight to the 351.
Old 07-29-2006, 05:45 PM
wafrederick wafrederick is offline
Banned
The computer is differant too,the I6 computer does not work with the v8.Ford does this: a 6 month change on their designs.My father's clean up guy has a 1991 with the I6 with close to 300,000 on it with no problems.
Old 07-29-2006, 11:52 PM
Believer45 Believer45 is offline
The 300 cu in I-6 has one less horsepower and two less lb-ft of torque than a 302 V-8 but does this at half the RPM (it may be 2 hp and 1 ft-lb, I forget which - spec is from 1983 trucks as well, I had one and contemplated the same swap). Personally I agree with others here, I would keep the I-6 - in fact I did. If you want to build it you can get cams, headers, 4 barrel intake manifolds and any number of other goodies for it. I didn't do all that though.
Dave / Believer45
'95 F250 power stroke 5 spd 4x2, extended cab, long bed, 3:55 rears, open air filter, 285/75x16 Cooper ATR tires, LUK single mass flywheel conversion, Putco master boss running boards, aluminum cap on bed, custom rear bumper (@450 lbs), scale weight full of fuel, me in it (285#) - steer 3420 lbs drive 3160 lbs gvw 6580 lbs, 280,000 miles as of Feb '09
Also 1996 Chevy Cavalier 2.2 auto 4 door LS, 95,000 miles.
Old 10-07-2006, 06:55 PM
1990 1990 is offline
No inline six will ever beat the 302. Fuel milage is better in the 302, torque kicks several chevy butts, and the 302 is bags more fun to work with. If you can, get a dome and carb kit, less milage but more fun.
Old 10-11-2006, 11:18 AM
bucketabolts bucketabolts is offline
tthe I6 is a more reliable motor though.
