Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 07-11-2006, 10:27 PM
murlybird murlybird is offline
Suspected fuel supply problem
I have a 1993 bonny se that when the gas tank drops to around a half tank or less, and in turns or under acceleration, engine will hesitate and sometimes stall. I'm thinking possibly a fuel pump, clogged screen or the sending unit. Please help, I don't want to spend the money to replace all three.
Old 07-12-2006, 04:49 PM
maxwedge maxwedge is offline
A990 racer
Lightbulb Re: Suspected fuel supply problem
Check the fuel pressure as this happens, if low either way the tank comes out.
Old 07-12-2006, 08:50 PM
daman daman is offline
It's in the gas tank,,they had bad baffels in them that year '92-3
it doesn't do it when you have 1/4 or more does it???
1999 GMC 3500 SRW 4x4 7.4 4:10's FF G80
2004 Chevrolet Impala LS 3800
"ALWAYS"...... full synthetic!!!
Old 07-15-2006, 12:09 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
The 92-94 H-bodies that came with the Nippondenso pump have fuel pick-up problems that cause exactly what you are describing. The new design replacement pump and strainer will take care of the issue, so it sounds like a new fuel pump is what you most likely need. Do like Max suggested and check fuel pressure when the problem arises to be sure. No sense dropping the tank to find out it's something else.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
