Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 07-11-2006, 09:40 PM
goldsgymdamon goldsgymdamon is offline
Question about my clutch
Hey everybody. Hoping I can get some help from you guys about my clutch. I have a 1994 nissan sentra and for the longets time it was so hard to push in the clutch. it was so tight.
finally last week I got a clutch adjustment and it was fine after that.easy shifting,etc. 4 days later i am on a busy street coming home...I push the clutch in and it sounded and felt like a big snap! Like a pop. I couldn't believe it. I pulled over and assumed that the clutch cable was broke.
well I can still drive the car. its almost like an automatic now. Except when I stop I have to put it in neutral and shut the car off, turn it on again to get moving in first gear. So anyways...looked at the cable...looks loose. I took it to the place that I got the clutch adjustment at today and the guy said I need a new clutch. How do I know if he is right? any insight?
Old 07-12-2006, 08:01 AM
nismo_pilot nismo_pilot is offline
Send a message via AIM to nismo_pilot
Re: Question about my clutch
sounds like its busted, try getting an opinion from a shop that wont be making 700 bucks on a clutch install and see what they tell you just to be safe
2005 Aztec Red Spec-V
Nismo header, ES MMI, AEM CAI, UR Pulley, TB Coolant bypass, TWM SS, Kumho Ecsta's, 2x JL Audio W0 subs
9.02@ 84.4mph in the 1/8th....... Driver > Car
Old 07-15-2006, 11:12 AM
slideways...'s Avatar
slideways... slideways... is offline
is the sentra a cable clutch? i thought it was hydraulic...
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 07-15-2006, 11:16 AM
let me clarify...the hydraulic clutch system is very much like the brake system. there could be a problem with the clutch anyways, but instead of the clutch cable, it uses a 3 piece line from the clutch master cylinder to the transmission, with the middle piece being rubber like a brake hose. maybe the rubber hose popped...look under your hood for your brake master cylinder, and then if you have a clutch master cylinder, it will be a little tiny version of the brake master cylinder right in the rear corner next to the fender. see if its still full. otherwise id say the shop is on the right track saying its the clutch.
Old 07-17-2006, 12:45 AM
fugiot's Avatar
fugiot fugiot is offline
Send a message via MSN to fugiot
Huh? My SE-R was a cable clutch. The GA's are hydros?
SR20 powered SE-R: 60mph-6.2 sec., 1/4mi.-14.7 sec.
VG30 powered Maxima SE: 60mph-7.8, 1/4mi.-15.8 sec.
Don't make me ANGRY
Or I will kick you in teh NUTS
Your NUTS will feel teh steel toe
Teh steel toe that has been in teh snow
I will rip off yuor pants and kick yuo in teh nuts
My steel toe will stick to yuor nuts
And I will swing yuo around by yuor nuts as I do a Hurricane kick
Old 07-17-2006, 09:50 AM
Chiquae07's Avatar
Chiquae07 Chiquae07 is offline
Send a message via AIM to Chiquae07 Send a message via MSN to Chiquae07
^thats what i thought as well. if so it makes no sense then upon nissans part.
Old 07-19-2006, 12:15 AM
JerodKing JerodKing is offline
Send a message via AIM to JerodKing
It's totally a clutch cable. Take it to a different shop.
